Question about Danze & Single Handle Tub And Shower Faucet
No cold water, Only hot water in showers.
When i turn the single handle the water is cold until the hot water heater kicks in. Once the water turns hot, it stays hot. Even at the coldest setting, the water comes out hot. This problem occurs at both of my showers which are back-to-back. It occurs at NO other locations in the house. All other faucets have hot and cold water.
  • 1 more comment
  • jkay395 Jun 01, 2009
    I'm guessing they were installed in 2006 which is when the building was built. I just bought the unit which was a foreclosure so I am not positive. I'm guessing that if the former owner took the faucets that he wouldn't have replaced them. So I think they were installed in 2006
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    Were these faucets just installed?
  • Kumar S. Sriskanda
    Kumar S. Sriskanda Aug 12, 2012
    I have the same problem now but it was working properly earlier. I think it is perrin and rowe part. I fear that it is clogged into the faucets. If so, how to clean it?
    Guru:
  • 597 Answers
The plumbers screwed up when they installed your showers. There are two connections on each shower. one for hot and one for cold. they connected the two hot water lines together with a T fitting and then ran a line to the main hot water line and tied it in. Then they connected the two cold water fittings with a T and ran that line to the main hot water line and tied it in there instead of into a cold water line like they were suppose to. This is the only possible logical solution to this problem. They tied your cold water connections to both showers into a hot water line instead of a cold water line.
Posted on Jun 01, 2009
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
On demand hot water heater gets cold for a short while during showers.
Check for crossover.
Bad single-handle faucet cartridge causes cold water to enter hot pipe, so hot never arrives and tankless does not run consistAntly
http://waterheatertimer.org/Crossover.html
Apr 13, 2013 | Bosch AquaStar 2400ES-NG
I have a Powerstar Electric tankless water heater, 45-551301, installed in a new home less than 3 years ago. We have always had minor problems with the hot water staying hot, fluctuations in hot and tepid...
Tankless heater are a little frustrating sometimes but this is generally an issue of waterflow I believe. The fluctuations are do probably to the amount of water and rate of water going through the heater. If you have a shut off valve on the cold side of the heater, shut it back about half way. This will slow the water going through the heater and allow the heater to heat it up more efficiently. Then go to the shower, turn the hot on all the way (no cold) and allow it to heat up. Once it has heated up, test it by hand for a good temperature that you like. If it is too hot, turn the cold on just a bit until it comes to the temp you like. If it is too cold turn the hot down just a little (still no cold) and it will warm up. Ideally you should be able to turn the hot on full blast and then just turn on a little cold to get the right temp. Once you learn how these work then it makes it easier. You really cant run the water like you do with conventional hot water systems and expect to get the same results. Also, wanted to give you another little tip. Every 6 mos to a year, you should flush you heater with vinegar for about 30-45 minutes using a small cheap submerible pump like for a water feature in a garde. Just put in a bucket of vinegar and and run a hose to the "in" side of the heater and another from the "out' side of the heater and then back into the bucket. This will circulate the vinegar inside the heater and clean all the deposits that will DOA your heater. Funny how the manufacturer wont tell you this but these deposits will ruin the connectiosn on the heating elements. You can make your heater last for a long time if you do this.
Mar 27, 2011 | Bosch PowerStar AE115 Tankless Water...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Danze & Single Handle Tub And Shower Faucet  Logo
3,370 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
