Question about Lincoln Welding Tools
My sp100 works,but very poor almost no spark.
    Sniper:
  • 58 Answers
MAke sure you have a good grond and a good connection between the welder and the ground cable and the ground cable and the clamp, Check the wire feed speed. Try turning the wire feed speed down. Make sure you have it on the right heat setting.
Posted on Jun 09, 2009
How to remove SC542 in ricoh SP100 SF
Enter service mode (hold down up/down for 5 seconds then hit #) service mode 5-810 to reset (fuser problem)
Apr 27, 2014 | Ricoh Aficio AP3800C Laser Printer
Simplicity sp100 quik press repair
Many current machines you need to take apart to oil. Then you oil every surface that rubs. Such as all the bushings and linkages. The exception being the tension discs.
Jul 28, 2013 | Sewing Machines
Toyota sp100 sewing machine - can't lower foot pressure on clothing
Berend: Thick fabrics require a longer stitch length. If the longer stitch length doesn't work check your attachments for an Easy Feed foot (It sort of mimics a walking foot.)
Dec 06, 2012 | Sewing Machines
When do the spark plugs need changed
Spark plugs like any electrical device become worn over time. Spark plugs also work under extreme condition. The use of cheap fuels will leave deposits, poor maintenance, bad air filters, old plug wires, all these items can cause a spark plug to fail or not perform at its peak level. Also spark plugs use a gap or Electrical bridge that is used for high voltage to arc across. The larger the gap the hotter the spark until you reach a point that the coil can not bridge the gap and then you get a misfire. Also when a plug gets deposits from either oil, poor fuel, carbon this will shorten the gap and cause a weaker spark resulting in poor performance, wasted fuel and engine dieseling or Run on after the ignition is turned off.
These are the simple reasons for spark plug replacement.
Jul 19, 2010 | 2005 Dodge Caravan
I have a 1978 yz 125 with a poor spark. It won't stay running.
poor spark or poor compression, replace the spark plug cap (piece that goes on spark plug to coil wire)
Feb 07, 2010 | Yamaha YZ 125 Motorcycles
Ground Splice Pack Location, 2001, 3.5
I'm not sure where the Splice Pack SP100 is but I can tell you what grounds fixed my AC problem.
I have a 2001 Aurora. The first two times I had intermittent air conditioning problems it was two different ground wires that needed to be re-attached. You can find the ground wires by taking off the shroud underneath the front portion of the engine. There are two bolts that screw into the engine. They can be taken out with a 15 mm wrench. I had to put new ends on the ground wires.
Jul 26, 2008 | 2001 Oldsmobile Aurora
Cd player isnt loading
The cd player might be dusty get the air spayer
Aug 30, 2006 | Rio Volt SP100 Personal CD Player
Welding Tools Logo
201 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
