Question about Crunch GP1100.2 GroundPounder 1100W 1/2 Channel Amp Car Audio Amplifier
My Crunch Amp In My Blazer Has Stopped Working! Please Help!
I have a Crunch GP1100.2 amp hooked up to 2 Audiobahn subs. About a month ago, my Blazer was flooded from flash floods and the bottom inch of my amp got wet. I am running a red top optima battery under the hood and a yellow top battery for my stereo system. Recently, I replaced the red top battery with a regular car battery. Now, my amp or subs won't come on. Would this be due to the amp getting wet, or would it be due to me changing the red top battery with a regular car battery? I was told that since I changed the battery that the amp would need reprogrammed. Is this the case? I was thinking that the regular car battery might not be powerful enough to run the motor and the yellow top. Could this be the case? Please, let me know. Thanks!
  • ddavidson23 Jun 02, 2009
    I figured it out. My Dad had unhooked the hot wire that powers the amp when he switched batteries. lol
    Genius:
  • 1,144 Answers
NO if your amp is good any battery will turn it on. changing batterys does not require a reprogram?. id say amp is damaged from being wet. test to see if power is going in and out if nothing out bad amp..
Posted on Jun 02, 2009
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
P1100.2 no sound
have you checked your fuses. on the amp and your amp power wire also there is a power remote wire that tells the amp to turn on when you turn on your radio.
Mar 31, 2012 | Cars & Trucks
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
BOSS AUDIO SYSTEMS SE950 Car Audio Amplifier: I have a SE950 boss amp, hooked to 2 audiobahn 12"...
Sounds like you are over working this amp for sure.. Upgrading your power wire & battery might help, check your gain level on your amp to. This is not the volume for the amp. Its to get both amp and the cd player on the same page... And most of all if your subs are wired up to .5 ohm stable, see if your amp do the same... My answer to this ?? Upgrade your amp, Boss audio was never a good company to me, but that is my opinon. Audiobahn set up all the way..
May 16, 2010 | Boss AUDIO SYSTEMS SE950 Car Audio...
Speakers aint hitting????
i had the same thing happen to me and turns out my wires on the speaker inside the box popped off. might help
May 06, 2010 | Crunch PZi1000.1 Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Audiobahn Sub: AW1206T & Amp: A8002T subwoofer extra noise/pop
The RCA inputs to the sub may be unplugged or damaged. Check them both for the sub and for the amp
Sep 05, 2006 | AudioBahn AW1206T Car Subwoofer
Crunch GP1100.2 GroundPounder 1100W 1/2 Channel Amp Car Audio Amplifier Logo
321 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
