Question about Kenmore HE2 Plus Front Load Washer
Fault code 5 d - what does that mean and how do I fix it
What does it mean when the washer stops with fault code F20? My kenmore HE2t first showed an error code of F21. We cleaned out the drain pipe and were letting it run into the sink to make sure it works properly before hooking it back up. But now its showing a code of 5d. What does that mean?
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore front loading washer king size capacity plus lite up HE2t. what is wrong
Not sure but sounds like maybe ur suds sensor is trying to tell u something? If u use to much detergent especially if its not H.E detergent u can plug ur suds sensor, u can go online and put in fault codes for ur specific brand of appliance and it will tell u exactly what the code means case Im wrong
Oct 31, 2014 | Kenmore Washing Machines
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. Refer to the parts illustrations under the "Tub and Basket Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each washer comes with a technical data sheet located inside the cabinet. You will need to remove the lower toe panel directly below the door to access it. If it is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all troubleshooting tips, wiring diagrams and fault codes with explanations.
Dec 09, 2009 | Kenmore HE2 Plus Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
519 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
