Question about Yamaha CDR-S1000 CD Player
Yamaha cdr-s1000 cd recorder
I have a cd recorder,when i am recording it will get half way through the the recording and wait starts blinking and of course the cd is no good and if you finalize it the recording is not complete,what could be the problem.
I have a CD555 5 disc player - it just keeps opening up even when I press play
Posted on Nov 07, 2007
Disc types that have worked for recording in the past are getting a "Not Audio" error upon reading. Specifically HHB CDR80's.
hi, i would try not using cdr discs. alot of older decks had issues reading "r"discs try cd'made for music not data. that should fix u up.
Apr 19, 2016 | Yamaha Natural Sound Cd Recorder Cdr S1000...
My Yamaha CDR D651 appears to dislike new 50x maxell CD-r discs saying not audio. Works fine with 12x discs. What's wrong? Rowan
you probably have regular cd-r disks that cannot be recorded on in this unit. You can only use disks marked "DIGITAL AUDIO" for recording
Sep 16, 2014 | Yamaha CDR-D651 2-Disc CD Recorder
Does anyone know if it is possible to record from a DJ mixer onto the Yamaha CDR-HD1300 CD Player / Hard-Disk Recorder? -- i.e Can I record a live DJ set straight onto CD? And/or can I record a live set...
The recorder could not care less what the upstream audio device IS or if it's live vs prerecorded as long as the connection works and there is a signal.
Jul 21, 2011 | Yamaha CDR-HD1300 CD Recorder
I have a yamaha cdr-hdd 1500 the problem is to record from hdd to cd it makes an image file ok but it stops whan it starts burn the cd after 2 min
Try burning at a normal speed [longer process], if successful, erase the burned tracks from your harddrive.
or rearrange your tracks, starting with older recording dates, then
burn at high speed.
Jun 09, 2010 | Yamaha CDRHD1500 CD Player
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
May 16, 2009 | Yamaha CDR-D651 2-Disc CD Recorder
Need free copy of the instruction manual for Yamaha CDR HD 1300
Yamaha website has owners manual to download
Apr 11, 2009 | Yamaha CDR-HD1300 CD Recorder
Cant rec
you have to press the copy button twice to record from hd to cdr
Nov 27, 2008 | Yamaha CDR-HD1300 CD Recorder
Cdr s1000 help
Hi Rick
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
Apr 06, 2008 | Yamaha CDR-S1000 CD Player
Yamaha CDR-S1000 CD Player Logo
193 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
