Because a non logical reason the error “BREWUNIT BLOCKED” appears also when the cup heating circuit is open... after heater or fuses fails.., ?Gaggia should have informed in the net about this error message as an anomaly .
?So, before you change your Brew Unit or you CPU..,, just check continuity between the two yellow wires... and bingo!
SOURCE: Brew Unit Blocked
If when you first turn it on and it does not go through the self test and then says brew unit blocked. You may have a wire loose on the board, (common) The motor that drives the unit may be bad. In either case you should have a professional look at it. Google saeco repair and have choose an authorized saeco repar center.
