Question about Canon PIXMA iP2000 InkJet Printer
Lost absorber pad
I was washing out the absorber pad for a cannon printer and i dropped it and it went down the drain. Any idea where i can buy a new one?
  • 256 Answers
You may be able to buy them from Canon. But you may be able to rescue the one down the drain if you go under the sink and remove the "S" or "P" trap. Have a pail under the trap to catch any water and debris. Dump the trap into the pail and see if you absorber pad is there. Best of luck!
Posted on Jun 01, 2009
Ip5300 fault light flashing
Hi Good day!! I think the problem is that the waste ink tank is full and you need to reset it..
Please try these steps. and hope it works..
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
To actually drain the waste ink tank, you'll need to take your printer to pieces and find, clean, wash and dry the felt pads found in the base of the printer. This is a complicated procedure, but it is a good idea to do it if you're technically minded. Many people have just reset the code without actually draining the pads and very few have run into problems as a result. If you do this, you risk damaging your printer and/or the surface it sits on if the pads absorb too much ink. However, if you're going to buy a new printer anyway, you might just reset the code and stand it on a piece of paper or card. It's up to you, just understand the risks.
Thank you
Aug 29, 2012 | Canon PIXMA iP5300 InkJet Photo Printer
Printer states waste toner absorber nearly full. Action?
You need to call Cannon and order a new waste ink absorber pad.
#732-521-7230 M-F
Mar 02, 2011 | Canon PIXMA iP2200 InkJet Photo Printer
The wast ink absorber is almost full
the waste ink absorber is a small unit inside the printer where the waste ink goes in. it is a common problem in cannon printer. the ink absorber cannot be replaced mate so when it says full, buy a new printer because its not worth repairing it.
Jan 06, 2011 | Canon PIXMA iP90 Mobile Printer
Error 46,the ink absorber pad is full.
first, try to establish if this really is full absorbent pad, remove power cable from the back, wait 20sec, press menu/set key, insert power mains - in most brother printer/faxes this will display machine error code. if this is code 46, you are on the money, your absorbent pad is full (not necessarily, only counter is showing it as such in most cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if that do not work, then maybe really you need to replace absorbent sponge... it is done under warranty and if not technician in service centre.
if you want to do it yourself, remove cartridges, remove fron cover and on the right hand you will have "offending" sponge. either clean it (absorbent, lint free tissue is fine to remove excess first, then few drop of water and repeat draining process with tissue several time, at least till "cake" from the top is removed. best of course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
Jul 29, 2010 | Brother MFC-5460CN All-In-One InkJet...
My cannon printer/copy machine says my ink absorber is full. What does that mean? what do I do?
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges that collect the waste ink.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Oct 07, 2009 | Canon Office Equipment & Supplies
My canon pixma ip 1600 has a full ink absorber---is there any way to fix this or do i need to buy a new printer-thanks
Try to remove the absorber (wear rubber gloves--very messy) and wash it in hot water and detergent. You can buy the replacement part if you don't want to try to wash it.
Sep 15, 2009 | Office Equipment & Supplies
The waste absorber is full
Call Canon at 732-521-7230 and they will sell you a new ink absorber pad. You will need the reset code for your model printer. Find this by searching for canon used ink tank. One of the results should match your machine. You can also take out the pad(It can be messy so wear gloves), wash with water hose, let it dry completely, and reinstall it in the printer.
Jun 10, 2009 | Canon PIXMA iP2000 InkJet Printer
Where is the waste ink absorber in the ip1600
you need to do following:
1) Canons generally have four screws that hold the entire printer mechanism on the plastic base. Some models do have a power supply module that slides out of the rear of the case, remove this first. Remove the four screws holding the printer mechanism onto the lower case. Some models may have more screws, but becareful not to remove any other screws! It just lifts off.
2) Take the waste ink pads out and lay them down on some newspapers by the sink. Set the waste ink pads in the sink. Pour some of the cleaning mixture into them to dissolve the ink, then gently run hot water through to rinse it out. It will never look clean, don't try, just get it so there is little ink left in the wash water. It is a rather fragile felt-like substance so if you try too hard, you can end up destroying it.
Squeeze out as much water as you can. Do -not- twist it like a towel!
Reinstall the ink pads and reassemble your printer.
Once you've got the pad cleaned and the printer back together, you'll need to reset the counter or it won't print.
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
May 14, 2009 | Cannon Office Equipment & Supplies
Problem with my canon printer IP1500
You have a few choices before you start....
1) do the above proceedure and spend some time.
2) take the printer to cannon and spend some money.
3) buy a new printer and spend some money.
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
Mar 10, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
56 people viewed this question
old marine
old marine
