Question about Microsoft Xbox 360 Elite Console
3 red lights flashing and no repsonse
When i try to turn on my xbox the 3 red lights around the on button keep flashing with no response
    Problem Solver:
  • 9 Answers
Its the re ring of death m8 its happens wen ur xbox over heats and fries the system call up micrsoft or whoever you brought it from and if u have waranty onit u wont have 2 pay 4 it 2 get fixd if u didnt u will have 2 pay 2 get it fix good luck xx
Posted on Jun 01, 2009
  • gerrard1892 Jun 01, 2009
    right u say blackberry
    Sergeant:
    Champion:
  • 223 Answers
That is called the red ring of death...if you enter that into a search engine, you should come up with the solutions to fix the problem.
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Blinken red light around the power button
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Jul 26, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Two red and green lights around the on button?
http://ezinearticles.com/?What-Do-Xbox-360-Red-and-Green-Lights-Mean?&id=1981493
Jun 15, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Three flashing red lights
this means your system is not properly conected also on yor video conponent check to see if its set on tv or hd mess around with it
Jan 03, 2008 | Microsoft Xbox 360 Console
Console with 3 red flashing lights
iv noticed that my xbox started flashing red and froze so i turned it off immeditly and felt the connections in the back were really hot and my xbox was really hot so iv moved it to an area where it could get good ventilation and keeps cool. havent had any more problems turning red it blows out alot of hot air out the back it needs to breath.
Dec 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
130 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
