Question about Mtd 22" Yard Machine Push Mower
Briggs & stratton 4hp push mower
It started running erratically...rpm would slow and speed up then slow again and speed up again. started using more gas and then stopped running. spark plug okay, air filter okay...any one know what the problem is?
  • Frank
    Frank May 11, 2010
    check the fuel line from th etank to the flow.unscrew the little round can from the buttom and clean it our with gas. make sure the gasket is installed whed you put the can back.
Why dose my motor cycle up & down in rpms
Posted on Aug 05, 2009
    Problem Solver:
  • 4 Answers
It is the cheaply made carburater that needs to be replaced with a new one. There is no adjusting the plastic junk.
Posted on Jun 07, 2009
Why won't my Briggs & Stratton 190 cc engine stay running?
probably a carb problem if it will start but not carry on running, possibly dirt in the float bowl
Jun 10, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Jul 01, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
5.5 Briggs & Stratton push mower running too loud
It could be the govenor spring. Get the model number, type and code and take it to a small engine parts store and get a new one. A new spring will slow down the rpm's and it wont be that loud. Make sure you remember how the spring was hooked up.
Let me know if this helps.
Thanks \
roundo4
Aug 25, 2009 | Garden
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
2,111 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
