Question about Kenmore 73952 Gas Dryer
THE DRYER STOPPED PRODUCEING HEAT.
I HAVE A KENMORE HEAVY DUTY SERIES 70 GAS DRYER THAT NO LONGER THROWS HEAT. I THOUGHT I COULD GET TO THE HEATING ELEMENT, HOWEVER IT IS BURIED SO THAT YOU WOULD ALMOST HAVE TO DISASEMBLE THE ENTIRE THING TO GET THERE. WHAT SHOULD I LOOK FOR. THANKS
  • 6,784 Answers
Check the following to address the non heating issue
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 02, 2009
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
I have a kenmore heavy duty 70 series gas. not heating up. were is the heating element. could you send a technical manual.
Your dryer does not have a element. The problem is either with the igniter, or the gas valve coils. I would replace both of them. I think they would run about $35.00 for both. Here is a link to the parts.
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Igniters-and-Gas-Valve-Coils/index.aspx
Nov 22, 2010 | Dryers
My dryer won't heat up at all. Model #96575100 Heavy duty 70 series soft heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 07, 2010 | Kenmore Dryers
How do I open up my kenmore 70 series dryer, it stoped running and I want to check and see if it is dirty, as that has caused this before
LE7680XSN1 Model Serial M80824319 Whirlpool Heavy Duty Dryer. Runs fine but will not heat. What should I check to get the heat to work
Dec 15, 2009 | Kenmore Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
282 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
