Question about Hotpoint WD62 Front Load Washer / Dryer
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Why dose my aquarius 1200 washer dryer wd62 keep tripping my electric please help as its doing my edd in
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    Do you have the correct rated breaker(s) for your washer 40amp? 50amp? etc.
    the instructoin book will tell you what size breaker(s) you must have and, then check the breaker box to see that you have the right ones(s)
Use a stiff new paint brush and give the motor and controller board a good brush
what happens is the carbon drum motor brushes deteriorate
and the left over dust can cause mains tripping as it allows conduction to earth at the motor brushes and plug
you can look for this one for days
its worth noting that there is two types of mains detectors
one is earth leakage ELCD and this usually trips the whole panel
and the other is MCB type just trips one circuit like sockets
so if the MCB trips this is over current and if its just the ELCD this is earth leakage and will be the heating element or dust build up
i agree with the other answer
it would be helpful to know what part of the cycle it fails at
this will tell us more
forinstance if it fills with water then stops and trips
its gona be the heating element
if it trips as it starts to turn its the motor
its something to do with the motor
remember the heating element wont come on till about 1min into the cycle
Posted on Dec 04, 2014
  • Hotpoint Master
  • 3,463 Answers
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Posted on Jun 01, 2009
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
Jan 24, 2011 | Hotpoint Aquarius WD640 Front Load...
Keeps tripping electric as soon as is turned on
Remove the lower rear panel of washer, and unplug the motor lead, then try again, if it still trips out, then disconnect the leads from the heater element, try again, if it still trips, then I would suggest you call someone in to check it.
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
I HAVE A HOTPOINT AQUARIUS WD62 WASHER DRYER. THE DRYER FAN TURNS ON BUT DOES NOT HAVE ANY HEAT COMING THROUGH, ONLY BLOWING COLD. CAN YOU SUGGEST WHAT NEEDS CHANGING? THANKS - RICHARD S
It will be a faulty thermostat or element more than likely, or a broken wire.
Remove top cover, and you will see the heater manifold over to the right side, there you will see the element and thermostats.
You will need a meter to test them.
Hope this helps.
Jan 10, 2010 | Hotpoint Aquarius WD63 Front Load...
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
807 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
