Question about iLO (2 GB) MP3 Player
Charging I am not sure how to charge the MP3 player. I have it connected to my computer and it says on the screen that its connected. However when I disconnect it from the computer (after 3 hours) it does not turn on. I did this on different computers as well. Even though I just bought this, does it need a new battery already? If so, how do I locate and remove the battery?
  • RjSteelflix May 11, 2010
    where is the battery cover
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
It runs on a AAA battery for power. Hooking it up to your computer is for adding songs only. Remove the back cover to replace the battery.
Posted on Oct 24, 2007
I plugged my mp3 player into my computer and how can I tell if it is charging and when it is done charging?
Go to "my computer" (or whatever it's called in your operating system) and right click on the MP3 icon, pick properties it will show a battery with the percent of charging.
Aug 12, 2016 | Eclipse Fit Clip 4GB* MP3 Player
My mp3 player will not charge
Sometimes it helps when you keep the cord connected to the computer and use the function to disconnect it from windows. The screen will turn from "USB connect" to "charging". This worked for 2 or my 3 players....not sure about that third one.
Sep 18, 2012 | Ematic e8 series
I have Sony NW-E503 (256 MB) MP3 Player. I have a problem when am charging my walkman I get a message "CHARGE ERROR". Can someone help me solving this problem? I am charging my player with...
I'm sorry that the Player is not charging as expected. It is possible that the usage of non-original cable will give the Charge Error. Please follow the below troubleshooting steps and check the operation before purchasing the original cable to make sure that the issue is not with the player or the connectivity.
  1. Please make sure that the USB connection to the Computer is secure and firm.
  2. Try connecting the player to a different USB port on the Computer.
  3. Avoid connecting to USB hubs.
  4. Try removing other USB devices otherthan keyboard and mouse.
  5. Restart the Computer and try again.
  6. Try connecting to a different Computer to confirm the issue is not with the Computer.
Thanks for understanding. Please let me know if you require any clarifications.
Oct 18, 2011 | Sony NW-E503 (256 MB) MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
Not sure if player is charging
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
Can you see the player in Coby Manager - under the "DEVICE" tab?
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    MP3 Player Not Charging!!! (USB)
    The most common cause is a flat battery. There is a trick to charging
    the battery in these small mp3 players. It wont charge if it is turned
    on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
    1. plug the payer into your USB port. or wall charger
    2. switch thje player on
    3. turn it off by either holding down the play button, or selecting
    "System" from the menu
    4. The screen will go black and the battery will begin charging.
    Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
    MP3 will not stop charging
    It could be the usb cable,so shop around for another usb cable for it, if that doesn't work take it (The mp3 player) back to best buy and tell/show them what happened.
    Jun 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
    Mp3 not working
    i can't help with ur mp3 not working but i had a similar problem with my mp3 not charging i just realized you had to turn it on it didn't say on the guide book it came with but i'm creative n then i turned it "ON" and it was charging i hope i helped someone with this simimlar problem
    Nov 29, 2007 | BenQ Joybee 125 MP3 Player
    Audiophase KZ111 MP3 players won't charge
    One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
    Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
    iLO (2 GB) MP3 Player Logo
    29 people viewed this question
    Top iLO Audio Players & Recorders Experts
    Mohamed Ismail
    Mohamed Ismail
    Michael Vincent Cruz
    Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
