Question about Kingston 2GB Secure Digital Memory Card
Flash drive write protected? can't add files
I cant move my files from my computer to my flash drive because it says that my flash drive is write protected.. how can i fix this?please i need your help tnx I have a 2gb Kingston microSD card that I am trying to add music files to for use in my sansa e200 series mp3 player. I used Windows Media Player and got a sync error simply stating that "WMP cannot sync the file to the device". The card does show up properly in my computer and my mp3 player. I tried formatting it on my computer based on instructions on Kingston's website, but I got a message saying it was write-protected. Please help! Thanks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Posted on Jan 08, 2010
I just wat to delete certain pictures from my flash drive and it's not working. What should I do? the flash drive is called ATTACHE.
Hi there
You flash disk is write protected and you cannot delete or add new file from the flash disc. Just click right mouse and choose the program each text. One of those is the tools to unwrite protect the flash disk or if there is pop up software in your computer that use to write protect the flash disc.
I hope it helps you
Feb 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
I'v inserted my flash drive on other computer and try to save some files, after saving i inserted it to my computer and scanned it. wen i was removing the virus, dialog box told me that it cannot delete...
There is a free program called unlocker which will allow you to delete,move or whatever you want with a file. this program will even delete protected system files. you can find it here http://ccollomb.free.fr/unlocker/
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant remove write protect
Download this small file:
http://www.kellys-korner-xp.com/regs_edits/writeenable.reg
Save the file on your desktop. Then double click the writeenable.reg file and click on Yes when Windows asks if yo u want to write to registry.
That;s it. Now you can try to create a new folder on your usb drive and it should be created. That means it's now normal.
HTH,
Regards,
Deboo
Feb 16, 2009 | BUSlink Electronics - Others
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PNY Write Protected
Check and see if you can copy and paste that file from it's location and place it on the desktop. Basically seeing if you can move that file within your PC. If this is a work computer, it might have precautions built-in to write protect it's documents. If you can move the file around in your computer then it's probably a problem with your flash drive. Can you copy anything to the drive?, such as a simple text file, music, etc. I'm also assuming that you checked the properties on the drive itself to make sure it wasn't locked. You could also try another flash drive to eliminate the possiblilty of your stick being defective.
Let me know how you do.
Sep 05, 2008 | Computers & Internet
Flash drive write protected can't move files
a small lock is presents in side of your flash drive ,u just change the current position of this lock
done,now try to copy or your work
regards prasanna
Mar 06, 2008 | Electronics - Others
Kingston 2GB Secure Digital Memory Card Logo
1,222 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
