Question about Brother IntelliFAX-2440c Plain Paper Inkjet Fax
I have an IntelliFAX 2440C. I am getting the message "Unable to Clean"
    Sergeant:
  • 296 Answers
Hi
chek this usefull link for your prob
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_001.html?reg=eu&c=gb&lang=en&prod=dcp117c_eu
however it might be just because of A foreign obstacle, such as a clip or ripped paper, is in the machine.
try doin this(as per an usefull forum)
Open the scanner cover and remove any foreign obstacles from inside the machine. If the error message continues, disconnect the machine from the power for several minutes then reconnect it. The machine's memory will
hold faxes for several hours, so you will not lose any important messages. If the error message
continues after the machine was disconnected,please follow the procedure below to transfer
the faxes to another fax machine.Check whether the machine has faxes in memory
1. Press Menu/Set, 9, 0, 1.
2. If the machine has no faxes, disconnect the machine from the power source for several
minutes, and then reconnect it.
—OR—
If faxes are present, you can transfer them to another fax machine. Go to Step 3.
—OR—
For MFC-620CN, you can forward the remaining faxes to your PC. Please see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be forwarded.
4. Press Mono Start.
5. After faxes are transferred, disconnect the
minutes and then reconnect it.You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in Step1.
Transfer faxes to your PC (MFC-620CN only)You can move the faxes from your machine’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ? or ?, select 1.PC Fax Receive,
and then press Menu/Set. The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
—OR—
To keep all faxes in the machine’s memory,press 2.
4. After faxes are transferred, disconnect the machine from the power source for several minutes, and then reconnect it.
OR
chek this link thoroughly
http://www.fixyourownprinter.com/forums/printer/54104
Hope it will work..
do let me kno
thnks
Posted on Jun 01, 2009
My brother intellifax 2440c won't print, copy or fax
well, you didn't say much, what happens? lights blinking? error code? power on?
general troubleshooting assistance answers to many error messages and problems at
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=fax2440c_us_eu
Sep 08, 2008 | Brother Office Equipment & Supplies
How can i get my 2440 c to use black ink only.
Mono Start
Lets you start sending faxes or
make copies in black and white.
Jan 17, 2011 | Brother IntelliFAX-2440c Plain Paper...
Getting the same message, unable to clean, followed directions in the book for troubleshooting and it still does not work. intellifax 2440C...
Remove the paper tray and shake all excess debris from it. Open all ports on the copier and rotate all cogs {gear wheels} by hand and watch for the smallest piece of paper in each corner. Get a can of compressed air and spray simultaneously as you spin the wheels. Make sure to unplug the unit before reaching inside to rotate gears. Turn copier upside down and shake any loose debris out. Close covers and replace paper tray. Plug in and try again.
How to I change my voice message on my 2440C ? It is a brotherintellifax.
Under this link you will find the manual for your MFC 2440C Intellifax. Go to chapter 7-6 and you have all related information for voice messaging:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000271/FAX-2440C_UkEngUsr.pdf
Hope it helped.
Nov 22, 2009 | Brother Multi-Function Center MFC-240C...
Doesn't recognize ink cartridges
Does the operator manual require you to do something when a drum is installed, on the control panel. check you manual?
Aug 18, 2009 | Brother IntelliFAX-2440c Plain Paper...
Message: Unable to Clean
machine error 46 means that your printer's purge unit has reached its counter limit and needs replacing, the reason i say this is because your machine has done alot of work and parts will be warn in your m/c, if you just reset the counter you will end up with ink througout your machine, normally when your printer is up for a purge unit its better to get a new machine with new cartridges and a 12 month warranty and no wear.
Jun 01, 2009 | Brother IntelliFAX-2440c Plain Paper...
Can't find UBS 2.0 interface plug. for my intellifax 2440c
You have to open the machine up to see the port. It's by the LAN port.
Sep 28, 2008 | Brother IntelliFAX-2440c Plain Paper...
Intellifax 2440C printer not printing
could u pls elaborate the problem
1. do u have sufficient print cartridge?
2. paper is fed correctly (no jam)
3. printer driver is installed properly?
4. No conflict between drivers among the resources for the printer?
have a nice day
bye
I hope my solution was useful
Feb 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX-2440c Plain Paper Inkjet Fax Logo
65 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
