Question about Navman F20 GPS Receiver
Help my navman isnot charging . ineed to send it off 4 repair. where and how
  • 363 Answers
Check the charger with a multimeter for voltage on the charger lead. If there is no voltage then this is as fault.
You should return it to the dealer if still under warranty.
If the fault is within the F20 then you should definitely take it back to where you purchased it. If it is still under warranty then the dealer should replace it free.
If this is not possible and because you did not specify your country you will have to go to a search engine ie www.google.com and type in "navman repairs" Paris. Include the quote marks and substitute Paris for your city.
When you are sure of a good result with an AUTHORIZED Navman service center, go to the repair center web page, find their telephone number and ask them if they are able to repair your device.
If you are not able to take the device to the center then tell them you will be sending it by your postal service.
Just wrap it up well in a box, preferably the box it came in. Include all the parts. And send by recorded post from your post office. Insurance is recommended and usually quite cheap.
Good luck, and if you want me to do the searching for you then come back and comment with your Country and city, I'll try to find a repair center near you.
Posted on Oct 23, 2007
SOURCE:
Is this my 600 LMT Navman already charged in build or have to charge from computer?
Best to charge unit from Mains or Computer USB, then you know it's fully charged. Navman has charge in battery but you need to fully charge it yourself , then you know where you are.
Mar 07, 2015 | Navman GPS
Hi I have a navman f20 which shows a batterey with a x on the display then turns off I have allowed the unit to discharge fully when on recharge it shows the same display
The battery is defective or your charger is not working. Most likely it is the battery but the charger is a possible until checked. You may want to find a gps shop and find out if they can get a battery.You can also contact Navman and talk to support about sending it in to them for repair. The battery should be about $20 plus labour to install.
http://www.navman.com/
Sep 06, 2011 | Navman F20 GPS Receiver
Ineed a manual for a F15
http://www.navman.com/docs/manuals/navman-f15-f25-manual-en_us.pdf
There is a 70 page manual. Not that its much help if the satelite signal doesn't kick in.
Nov 25, 2009 | Televison & Video
Erreur f20
This is a fault with the internal memory chip failing. It can not be fixed and requires the unit to be sent to Navman and the chip replaced.
Return your GPS to the place of purchase and they will complete the return for you if you've had it less than a year. You will need a repair ref number from Navman before sending it back.
This would cost you if the items out of waranty.
PLEASE rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 11, 2009 | Navman F20 GPS Receiver
My navman s50 wont boot up
Try to send it to a repair centre .
Try here if you whant
www.satnavservice.com
Sep 01, 2009 | GPS
Navman F10 not starting
Apparently, according to the Navman helpdesk you have to open NavDesk and from the menu, go to Tools and then Recover Keys .
I tried this on my S80 and I got an error, (E000050) which I was then told I had to send the unit back for repairs. This is my worst purchase ever. I'm on my third unit and have had nothing but trouble.
Dec 06, 2008 | Navman Tracker 5500i GPS Receiver
Can I connect the wires from a car charger to the connections under the unit ?
An alternative is to use a navman P1 "hotshoe" This allows charging to be carried out through the bottom strip connector.
Available from Magicgadgetz at a cost of £20
Oct 22, 2008 | Navman F20 GPS Receiver
Navman N40i Not charging in car
Does the car charger cord plug into the cradle? or just straight into the unit (despite resting on the cradle) ? Do you know if anything else charges via the car charger?
Mar 15, 2008 | Navman NavPix N40i GPS Receiver
Navman repair
Any electronics repair place or perhaps a camera repair shop should be able to fix it for your. Search google or your local phone book for electronics repair or camera repair. This is a very easy repair IF you are electronics savvy, but not a good first/learning project. This will require either soldering a loose connector back to the board or they may need to find and purchase a new connector to replace the old one if it is broken.
Nov 09, 2007 | Navman ICN510 GPS Receiver
Navman F20 GPS Receiver Logo
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
