Question about Fujitsu fi-5120C
How to scanning double sided document in fujitsu 5120c scanner
Hello ,
           how to scanning double sided document in fujitsu 5120c scanner ? what kind of setup i should in scanner utility or Kofax software setup ?
Thanks
Vasu
    Problem Solver:
  • 12 Answers
Use PixEdit. A wealth options, directly control Simplex duplex and so on with profiles and after scanning options like deskew, blank page removal, OCR, stamps, barcode recognition, automatic color and BW recognition, small PDF files and so on.
Posted on Aug 20, 2009
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Posted on Nov 29, 2007
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Hello, I work for a doctor's office and we scan a lot of documents. Lately we are getting a code ds42003 on a fijitsu scanner, what should i do this code is on the fi-4010cu, we also have a fi-5120c...
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
Nov 28, 2017 | Fujitsu fi-5120C
Scanning is quick, but processing the document is very slow
It looks the problem is with your Computer. Do you have enough disk space? Run 1) Scandisk and 2)Defragmenter and check if it is better. Do you have enough Video RAM? Try and increase using the BIOS.
S. Mohan, Chennai, India
Nov 20, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Scanning document
i had the same thing happen to me i went threw every thing and cleaned and still was there i came to realize that it wasnt the scanner but the software pdf that was being used the seriously took me by surprise so i went out and installed a fresh copy of pdf writer this resolved my problem with the pink markings
i hope this was of some use
Apr 24, 2008 | Fujitsu fi-5120C
Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Oct 15, 2007 | Fujitsu fi-5120C
Fujitsu 5210c Scanner
Uninstall the scanner software and also the program you use to access the scanner Restart the computer and reload the software[s] Or first try a system restore.
Jun 25, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fujitsu fi-5120C Logo
880 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
First Stop Tech
First Stop Tech
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
