Question about HP Office Equipment & Supplies
No power when I turn on
I had a power outage on friday and now my hp 4mv printer will not turn on. can you help. would it be a bad power display.
    Guru:
  • 597 Answers
Try plugging something else into the socket and if it works then the printer was probably damaged from low voltage or a voltage spike as the power was going off.
Posted on Jun 01, 2009
Power is on but the printer display won't turn on.
unplug the printer power supply for about 10 seconds, the plug back on, i have to do that to my wifes printer ever so often, most usually right after a power outage.
Mar 17, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Hp 4mv
You probably need to replace the paper feed rollers, which are no longer available from HP...
Mar 25, 2014 | HP LaserJet 4mv Printer
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Hp laserjet 4mv 67 error problem?
67 error is an "internal RAM, scan buffer, Dynamic RAM controller or miscellaneous interface hardware error. That's from the book.
If power cycling he printer doesn't fix it, have the formatter board replaced.
Aug 19, 2011 | HP Laserjet M2727nf Multifunction Printer
My hp 4mv is still printing but smells hot and there is a little smoke with it. Any thought? I'm a bit scared to use it.
Hello, the HP4MV is quite an older printer. it is possible, that if the printer has never been professional cleaned, that dust will accumulate inside the printer and settle on the power supply and cause overheating and the burning smell. The proper method for cleaning laser printers is to remove all of the covers and use an ESD (Electrostatic Shielded Device) rated vacuum to remove all of the accumulated toner and debris. the use of compreesed air is NOT recommended. I would advise to have the printer cleaned and it should good for many years to come.
Jan 14, 2011 | HP LaserJet 4mv Printer
HP LaserJet 4MV '50 service' on an HP LaserJet 4MV printer Can it be cleared without resorting to repairs or replacement parts?
You could remove the fuser, turn the machine off, and wait an hour. It may reset the error. However, if the error still persists, it will be a parts replacement of the fuser, low voltage power supply, or the DC controller. 90% it is the fuser. Good luck.
Apr 21, 2010 | HP Office Equipment & Supplies
Hp 4mv printer paper jam
take out the cable and then press the power button for 1 min
Feb 11, 2010 | Office Equipment & Supplies
No display
Low voltage power supply is toast.
Try unplugging the power cord for 30 mins.
Aug 20, 2009 | HP LaserJet 4mv Printer
HP 4MV Printr and ip address
Scroll through the menus until you get to the I/O section. I don't think vista supports the HP 4MV
Mar 12, 2009 | HP LaserJet 4mv Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
44 people viewed this question
Seeker5211
Seeker5211
