Question about Maytag Legacy Series Top Load Washer
Maytag washer noise during wash cycle
I have a knocking noise in my Maytag clothes washer during the wash cycle. Sometomes it comes and goes. Is there a simple fix?
Also, if I have to tear it down, can I do it without turning the washer over.
My model number is: MAV408DAWW
  • 30 Answers
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Posted on Jun 02, 2009
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Noise hear during washing cycle?
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Knocking in washer
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Loud noise
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Clanking, sparking sound coming from washer
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
Jun 11, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
1,235 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
