Question about GE Refrigerators
Not cold in freeze and fresh food
I have problem,that not cold in freeze and fresh food,what i do with it ? (americana)
    Problem Solver:
  • 10 Answers
The coils are probobly iced over, and need to be defrosted, may be low on freon.
Posted on Jun 01, 2009
E402b freezing food
there is a little door between the freezer and the fresh food usually when that happens the motor on that door is bad and sticks open and allows the fresh food to get to cold since your freezer actually cools the fresh food side, sorry i cant tell you where it is on yours since they are are different, it will be where the cold air blows in the fresh food side and the part is not usually expensive and fairly easy to replace.
Mar 23, 2014 | Fisher and Paykel Active Smart E522B...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Is there a difference between freeze-dried and dehydrated food?
Yes there is, in freeze-drying process they use a cold temperature and in dehydrated food they use warm temperature. In the freeze-frying process the fresh foods are frozen first then the moisture removed in a vacuum chamber and since the food remains frozen during the process, the food's cell structure don't change.
Aug 09, 2012 | Camping, Backpacking & Hiking
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
Icemaker overfills and freezes solid so wont dispense. also freezer has frost on everything
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this help out....
May 07, 2011 | GE Americana A4425GDTWW Side by Side...
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
Our refrigerator is freezing our vegetables. it is turned all the way down.what is the problem?
Is food freezing in the rest of the fresh food side as well, or just the food in the lower half, like in the crispers. if its freezing everywhere in the fresh food section, you have a bad cold control most likely, without knowing the type or brand, i cant be 100%. If its a GE, you could have a different issue, but most any other brand will be a bad cold control.
If the food is only freezing in the lower half, then your evaporator fan motor is likely the problem, located in the freezer
Mar 19, 2010 | Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
