Question about Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual Speed Pump
Sleeve where filter goes in is creaked anyway to fix without replacing the sleeve. THANKS SO MUCH
The sleve where the filter goes in is creaked, anyway to fix without changing out sleeve. THANKS SO MUCH
  • Jay Finke
    Jay Finke Dec 28, 2011
    hose clamp, car part store, or they make a 2 piece replacement fitting (nut) i have never seen a sleeve fail ..?
  • 110 Answers
I have been known to 'wire' up the skimmer filters to fix creaked skimmers.
Copper or Stainless wire
Posted on Jul 07, 2009
The flow switch on the Amana ptac unit is not opening causing water to build up. How do I get it to drain into the sleve?
run a coat hanger inside the sleeve and then spray some bleach through the fins and then put the filter back on and run it
Jul 26, 2015 | Amana Heating & Cooling
How do i change sleve of hp 2300dn ?
the sleeve you are referring to is the Teflon sleeve located in the fuser unit and is covers the upper heating element in the fuser unit.. unless you are familiar with fuser rebuilds don't attempt it.. you can purchase rebuilt fuser units or brand new OEM units From Precision Roller Part number is RM1-0354-050,or RM1-0354-000
Apr 24, 2014 | HP LaserJet Office Equipment & Supplies
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
My sleve is stuck in the spinning deal of my washer, how do i get it out?
Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
Feb 15, 2011 | Admiral AW22 Top Load Washer
Which direction does the plastic sleeve in the compression nut go where it connects the plastic water line to the solinoid on the Aprilaire 560 humidifier? Thanks.
Hello, I have posted a pic of how the sleeve goes onto the tubing, the sleeve in the pic is brass but a plastic sleeve goes on the same way.robhvac47_16.jpg
Feb 05, 2011 | Aprilaire 550 Humidifier
OBSTINATE SLIDING SLEEVE THUS PREVENTING FOLDING THE GOPED. ANY GOOD IDEAS TO RESOLVE?
Squirt a little anti-seize between the slide tube and handlebar and carefully twist and pull with all your might. once you have it off grease the surfaces that make contact with each other and do not let it dry out this time.
Aug 22, 2010 | Go Ped Compatible Scooter Bigfoot Drive...
Need the sleve that cover the battries
According to the pictures I see in the T70 manual, there is no sleeve required. It shows two AA batteries in the battery compartment, but no sleeve. Try just placing the batteries (properly oriented) into the well and closing the cover, and see if the camera powers on OK. You should be fine using it that way.
Feb 05, 2010 | Canon T70 35mm SLR Camera
How do you operate a quick connect tool?
not sure which tool/s you are intendung ?? however if you observe the tool it has a sleeve around its circumfrence this sleve has to be pulled/pushed back and held then the attachment/tool you wish to use ? can be inserted fully home then the sleeve released to ensure attached tool is locked ? try to pull it out if correctly locked it will not pull out so is safe to use to release tool attachment pull/or push back sleeve then pull out tool attachment the tool attachments must have hexagonal locking bits that fit into the tools jaws unless the tool is air line pressure quick fits then these have locking rings around the circumference the actual locking device is a series of ball bearings that are sprung closed untill sleeve is pulled /pushed back then the balls are slid up a tapered cone and outwards to enable tool attachment to pass balls then when sleeve released the balls move under sping back to lock position hope this is what you are looking for ? best wishes from uk
Jul 18, 2009 | 2000 Ford Excursion
Spark plug boot
hi im wes
the sleeve is a heat shield it keeps the manifold from baking the boot if you leave it off it will still work for a while it will however fail much earlier than if you put it back on hope this helps
thanks wes ps please rate me
Mar 26, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Transmission
does it have a gear or a reluctor wheel. if it has a wheel you will have to take the sleeve off first and be careful they bend easy. then you can drive it off with a brass drift, again be careful because they crack. gm has a special tool to removed and install these parts. hayden trans tool may also have one. you should measure the distance from the end of the output shaft ro the rear edge of the wheel this will be your assembly height.then put your yoke seal sleeve tube back on and your done.
Jul 07, 2008 | 1988 Chevrolet K1500
Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual Speed Pump Logo
57 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
