Question about Dolphin Maytronics Diagnostic Robot Cleaner
Stopped working After hooking everything up, I placed robotic pool vacuum in pool and turned it on. It worked for 30 seconds and then stopped. I turned unit off for 10 minutes and then tried it again. This time it didn't work at all.
    President:
  • Dolphin Master
  • 1,378 Answers
Try a self test...Flip the unit upside down on the ground, tracks 'up towards the sky' and trun it on. It should run for about 30 seconds during which it will cycle through various track and impeller motions.
If it completes the test, try it in the water again.
If not, contact us at www.arrowmotor.net for service arrangements or parts. You can also try Maytronics direct at www.maytronicsus.com.
Posted on Jun 14, 2009
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
Vacuum works, doesn't run
sounds like the rear wheel gear
if not
possible the brain in the see through box may be it
Jan 08, 2014 | Smartpool Dolphin Robo - Kleen Above...
Roomba 550 stops after 30 seconds of operating. Battery was replaced 1 yr ago to the date. Also makes screeching noise. Did clean the gear box in 1/13 but didn't put lube on gears.
OK, then maybe you should diassemble the machine and put some lubrication on the gears. Make sure everything is in it's correct place when re-assembly. Make siure the fan blade that creates the suction isn't damaged or even cracked. If it is, replace it. If it's stopping shortly after starting, it may have something OUT OF PLACE, that's causing to much friction.
Oct 15, 2013 | iRobot Roomba 560 Robotic Vacuum
The cleaner doesn't move. when I plug it in it comes on, the vacuuming starts but nothing else happens. the pool remains in one place, does not move.
If it is not working, it is likely a problem with the impeller being jammed or an obstruction being in your drive shaft. Try checking both of these places for jammed leaves, etc. This is a common problem with these pool cleaners.
Aug 09, 2010 | Smartpool Dolphin Robo - Kleen Above...
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
Transformer turns on but robot in water don't turn on no movemen t or water flow
I had same problem unplug unit wait for 30 seconds and try it again I had to do this 3 times this a.m. I am having problems with it only going 2 or 3 feet.
May 25, 2009 | Smartpool Dolphin Robo - Kleen Above...
Even with a new battery
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Apr 21, 2008 | Roomba Robotic Floor Bagless Vacuum
Dolphin Maytronics  Diagnostic Robot Cleaner Logo
535 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
