Question about Konica Minolta Magicolor 2530 DL Laser Printer
Minolta 2530 DL "low drum" message
I just got the "drum low" message, but the printer is working fine and copies are good. Is it OK to get the fuse reset kit like the one's sold on ebay and continue using the old drum? I see drum kits on ebay too. Should I go that route? thanks, ken
    President:
  • 1,185 Answers
The drum loses its ability to accept the image after a fair number of copies
A lot of machines monitor the drum voltages required to obtain a good print and when they go out of tolerance the report the error as Drum Low
It is telling you that the drum is on its last legs before it stops printing
Make sure that the Drum Kit is a complete unit with cleaning blade etc and follow any instructions such as wiping the drum with a bit of the toner powder before it turns.
This acts as a lubricant and stops the cleaning blade from digging into the drum surface when the machine first rotates
Posted on Jun 01, 2009
How to reset the drum
Pull drum out, look at bottom back for a small fuse. You can get the fuses at Radio Shack for a couple of bucks. Replace fuse. Print till pictures come out all messed up then replace drum.
Feb 04, 2012 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
May 18, 2010 | Konica Minolta Magicolor 2530 DL Laser...
What is the drum cartridge?
A drum cartridge is the rotating drum that puts the toner onto your copy's! You would need this to make copy's and after its empty, it would need replacing.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 22, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica Minolta 2530DL printer. I have
the reset is done via a 'first use fuse' in the drum unit.
check the contacts or put in a new one.
Oct 21, 2009 | Konica Minolta Magicolor 2530 DL Laser...
DRUM CARTRIDGE REPLACEMENT
open the cover of your printer press and hold the main button wait for the other 3 light go up release then close the cover
Sep 17, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Where is the drum reset fuse located on the Minolta 2530 DL print
you can find all details with picture shot on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
please post back if any changes and vote all answers.
good luck
Feb 07, 2009 | Minolta magicolor 2350 Laser Printer
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
469 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
