I had no problems installing this item.
Program is great and seems easy enough but I cant figure out the audio.
Video works fine better than i imagined.
Install the printer, then go to your startup folder and remove your printer so it cant start the services when you start windows.
Your printer will still work when you want to print items, but you may loose some functions like auto update and ink levels.
To get to your startup folder, type msconfig into the run or search box, or use a program like CCleaner.
You slowdown problem may be due to the amount of system ram, is the pc powerfull enough?
First the drivers need to be installed, then the program you use to scan may need to be told that's the scanner to use. Your program should then work fine
Usually you get a CD with it that does all that and supplies program for all functions.
I had the same problem i was under the impression I had a realtek audio system in my laptop but it turned out to be Conexant High Def sd2 i found it by accident but on the HP website ..so try your comps manufacturer web site and and search the driver section and u might get lucky, also right click on the driver select trouble shoot and click troubleshoot then select the program worked in an earlier version , then select your old OS (XP) then click start program and it should start to install, when it does and if it works select save settings for this device within the same trouble shoot window, u will have to do a lot of this seeing as how its an RC and not fully equipped with all drivers
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
probably you had a trial version which expired already and some features of the program aren-t available anymore ...reinstall the program ..or better look for a 2003 version cause in my opinion has all it needs to be a great program and I always found it enough for my needs...
You will need to change your default audio output device to be the USB headset. You can do this under Sounds and Audio Devices in the control panel. Change it from your regular sound card to the USB headphones. They should be on a drop down list.
i occasionally have this problem, the usb connection becomes corrupted, this is not uncommon for various devices with XP and Vista.
to fix, download a free small program called USBDeview (should come up with Google search easily). load and it will show you all devices that have connected to your system. Find the Canon XSi product and 'uninstall selected device'.
You may need to reboot one time, and then reinstall the Canon driver from the disc. In all it's a very easy process, the hard part is figuring out how to edit the usb registry, which that free program does nicely.
Sounds like your frig is not defrosting. Locate defrost timer and start manually. If that solves the problem, replace defrost timer. Another possibility is that the evaporater fan in the freezer compartment is not working. Both items easy to replace.
Why don't you go to the acer web page anmd go to the download page and type the name of your computer and download audio driver and save on to your HD and install(normaly you should get Realtek SOund Manager)
You should just download a copy of iTunes from apple.com for your operating system and then install it. Then you just plug your shuffle in and follow the instructions.
