Question about Frigidaire Dryers
Belt replacement on a frigidare stacked dryer
I need to replace the dryer drive belt on a Frigidaire Stacked unit. Model Number LCE752L-W-3. Instructions and tips will be appreciated.
  • 10,515 Answers
Check the below link :-
http://repair2000.com/wpoolbelt.htm
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Jun 01, 2009
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
How to replace v belt
Are you looking to replace the belt in the dryer portion of the stacked/combo unit?
Sep 23, 2012 | Frigidaire FEX831CS Top Load Stacked...
Hello, I am replacing a 15+ year Frigidaire
these are usually 220 volts.If the grey cord has three prongs on it it will be 220.
Mar 17, 2010 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Agitator will not move
Jac, my suggestion is this. The "reverse" gear in the transmission has locked up. The burning smell is coming from the belt. The motor is trying to spin the belt to turn the tranny but it won't turn  'cause it's locked up this causes the belt to burn.
If it's less than 5 years old, the tranny is under warranty. Contact Frigidaire and give them the full model and serial number and schedule a repair. (ask them to bring a belt with them when they come. you'll need one.)
Oct 11, 2007 | Frigidaire FGX831CS Top Load Stacked...
Dryers Logo
184 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
