Question about Panasonic PT-51HX41 51" Rear Projection Television
Red ghost images
I have red ghost on a panosonic pt51 hx41e. Is there a fix that the layman can do without risk of electric shock.
  • Panasonic Master
  • 8,617 Answers
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Posted on Jun 01, 2009
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
WHAT LAMP SHOULD I ORDER FOR MY PT51-HX41E
This Model PT-51HX41 is a Projection TV ,it has 3 Tubes Red/Green/Blue and does not have a Lamp. What makes you think that one of the Tubes is Bad? What Seems to be the Problem with set?
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Red light blinks5 times stops & does it repeatly sony KDF-60WF655
5 times red light blinks in Sony KDF-60WF655 shows problem with ballast supply that needs to be replaced.
If you are handy with electronics stuff repair and have service manual copy then can replace it.
Be Aware: electric shock risk is involve in TV repair.
Or contact local TV tech to fix it.
Need further help, let me know please.
Thanks.
Sep 22, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv has a ghost image in red
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 50H72 50" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
153 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
