Question about Maytag Dryers
Noisey when runing with a load
Noisey when runing with load.
  • 121 Answers
Your dryer bearings are going bad there is one directly behind the tub and you need to take the front off and take tub unit out and you will see the bearing directly in middle of back of tub
Posted on Jun 02, 2009
Will not spin and makes noisey
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
l;l,.,./
Mar 05, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
Nov 09, 2009 | Zanussi F1045W Front Load Washer
Noisey pump
Probably wear on the pump impellor, the only solution would be replace the pump, once you have made sure that there is nothing in it that could cause the noise.
Please rate my solution.
Thanks.
Oct 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Very noisey
Hi there. This noise you are hearing is coming from the gear case (transmission). You may have some alignment issues within the gear case that is causing the grinding. there also is a clutch system here in this location as well. i would have a look before the gear box locks up. this will shut the entire unit down if so.
please rate and god bless.
Mar 17, 2009 | Washing Machines
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Noisy agitateing
Fit new bearings
Nov 26, 2007 | Washing Machines
Dryers Logo
138 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
