Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
No power to radio wont even turn on
The inline fuse is not blown but, previously would blow. wont turn on and is plugged in/
  • 41 Answers
The most likely thing is what we techs call revers polarity. this means that the customer accedently hook up the power in reverse. this happens more often then not. The fix for this is to replace the 1 amp diode that goes between the negative and positive power input on the board. the Diode number is a 1N4007 or any 1amp silicone diode. You will also see that once Blown diode is cut the radio will come back on. this does not mean the radio is fixed what this means is that the shorted diode has been removed from the circuit. which also means the radio has nom protection until the diode is replaced.
Patrick Patterson N5SLI
Posted on Jun 02, 2009
  • cgarcia_6307 Sep 09, 2011
    es buena tu informacion yo no soy electronico pero si es entendible gracias
My 06 Audi a4 had a blown 20amp fuse for the radio. There was a lot of feedback noise coming through the speakers even with the radio off. I've replaced the fuse, so now the background noise is gone, but...
Check that power is actually getting to the radio. A cheap multimeter will do the trick. Connect the red tester to the power supply and the black to any earth (-ve). The body of the car is earthed so any bolt into the body will do.
Check that the radio doesn't have its own inline fuse which could also have blown.
It takes quite a substantial fault to blow a 20 amp fuse so take care, there may well be a dead short somewhere.
Nov 07, 2013 | Cars & Trucks
I have a Olevia 242-T11 and it has no blue power light, removed rear cover discovered blown fuse at power board, went to radio shack and found simular fuse 5A 250v but fuse keeps blowing out when powe
The fuse is always a protector and when it had blown a second time it is certain that there is a short or high current drain in the power circuit which exceeds the limit and so to prevent further damage or fire the fuse blows off. You need to just use a multimeter to check so as to confirm the short on the power supply unit.
Check this link for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jan 05, 2012 | Televison & Video
The radio will no turn on. we have all the wires connected the power cord is plugged in but when we press and or hold the mode button nothing happens. its a new radio that we are installing that was bought...
If it is a new radio first make sure your power wire is actually hot. Use a multi meter. Also you may have a blown fuse in the fuse panel. Check that. Make sure it is grounded as well. Improper ground will make it not power on as well. For this radio Blue = Remote that you run to your amp or power antenna. Insulate it if you are not using either. Black is Ground. Red = Your accessory wire and should only get 12 volts when the key is turned on (switched 12 volt source.) Yellow is your continuous power source. Hook this to your battery or other suitable continuous 12 volt power source. It also has a 5 amp fuse inline. Make sure it did not blow. Replace it to be absolutely sure. Use another 5 amp fuse. Never go higher. The other wires are for speaker hook up. If you do all this and still no power. You may have a faulty radio. Good luck.
Mar 06, 2011 | Car Audio & Video
Hello, i had my mcb-40 mounted in my jeep and it worked well. i switched it over to my new truck and now it will not turn on. no channel displayed, no sound. i have the power and ground both conected...
First make sure you are grounded well. Second do you have an inline fuse on your power wire? If so check that it did not blow. Even if it looks good throw another 3 amp fuse in to make sure. Also make sure your power source is actually hot and make sure the fuse in the panel fuse box for your power source has not blown. Also are you using the cigarette lighter? If so make sure the fuse to the cigarette lighter has not blown. Last you can try a new power wire. If you try all of these to no avail you more than likely have a radio issue. Good luck.
Mar 04, 2011 | Maxon MCB-40 40-Channels Handheld CB Radio
Previous owner put new battery in car, since then the CQC1303U unit will not work, not power. Fuse is not blown. Is there a code to reset? The car is a 94 Toyota 4-runner
did you try checking all of your fuses? there may even be an inline fuse to the radio. most radios require two power sources.
Dec 23, 2010 | Car Audio & Video
I wired my wires to a car outlet plug. i plugged it, it powered up, then the wires sparked and it turned off. i know i didnt ground it. i should of read the instructions first but im an idiot. i now cant...
hi, chk fuse for outlet chk inline fuse for cb radios pwr cable . If you polarized the power cable wrong
there is most likely a protect diode inside the case that may be shorting out aswell
Oct 08, 2010 | Midland 1001Z 40-Channels Base CB Radio
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
Dashboard Lights wont turn on
You have wired something wrong. Find a different power wire for your radio. Best to hook a power wire into the fuse box, and have an inline fuse for you radio. And then run a ground wire to your steering column or something.
If it's not that, then you must have pulled a wire off somewhere, and now it's grounding out and blowing your fuse. Have fun. Wiring sucks!
May 20, 2009 | 1986 Ford F 250
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio wont light up
Check the inline power fuse first/or replace it! If that does'nt work then next make sure the radio is in the operating possition on the switches labeled>cb/pa< to cb mode. If this does'nt work then you may have a wire from your power plug inside the radio broken loose or a blown diode. If in fact the wire is connected inside the radio the diode would be my next guess. This happens when the polarity of the radio is reversed(hooked up backwards). This can be fixed relativley easy at your local radio shop for about 30$. Good Luck.
Dec 18, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
245 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
