Question about Westinghouse Washing Machines
How do I replace the water level switch in my washing machine
I have a 16 year old front loading White Westinghouse washer. Sometimes the water fills way too high, even though the water level is set for a small load. I assume I need a new switch.
  • judyandjim1 Jun 03, 2009
    thanks for your help!
    President:
  • 1,185 Answers
You either need a new pressure switch or the pipe leading up to it via the air bell is blocked with a soapy jelly.
You can remove the back and then take off the plastic or rubber pipe leading down from pressure switch (It looks like a small flying saucer with several leads onto its plastic side and a small inlet pipe where the plastic pipe fits onto.
The other end will fit on top of a small chamber attached to the near the bottom of the main drum , this may be made of a translucent plastic which should allow you to see if there is any blockages.
If not it is a case of removing it making sure it is clean and if need be glueing it back into place with a good silicone sealer or instant gasket.
If that is clean and the machine still gets the levels wrong you need a new part
Posted on Jun 01, 2009
Only half filling with water
Water should fill to bottom of door . If not replace water level switch
Aug 07, 2014 | Bosch WAB28060GB Maxx White 600 mm Washer...
Why Dont I have enough water in my washer when washing?
The water level switch works off water pressure at the tub fills. The switch, or the tubing connecting it to the tank may need to be replaced.
Aug 07, 2014 | Samsung 4.2 Cu Ft Capacity White Front...
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My westinghouse leaks water. It's 16 years old, so if it's some major problem I'm ok with it and I'll get a new clothes washer. On the other hand I would like to open up the washer and
The back and sides are one piece. The front comes off (two clips under top, one on each side about 2 or 3" in from outside - two screws on bottom directly below clips). The top will lift up on the rear hinges, the front lifts about 0.5" and comes off.
Aug 02, 2012 | Westinghouse WWS833ES Super Capacity Top...
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the...
does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Jan 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
20 year old front load white westinghouse washer goes into spin cycle when knob is pointing to wash cycle
20 years old? And you expect it to still be working?!? You can't even get parts for it anymore.
Oct 19, 2009 | Westinghouse Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
