Question about Tomtom ONE GPS Receiver
My tomtom cant find any satellites and keeps saying waiting on valid gps signal......
My tomtom wont pick up any satellites it will not find a valid gps signal. It will load and find destination but will not proceed past that . The message says "waiting for valid GPS signal" My TomTom One has been trying to locate a GPS Signal for the past 3 days, prior to that it located the signal no problem in the same areas I've been since then.
  • cymruchris May 11, 2010
    Has the unit been inside for three days? Or have you had it in the car with you as you drive around? If so - what car do you drive?
    Brigadier General:
  • 4,090 Answers
Check the port is set to 8
not sure if your model has GPS search wher it finds the port and vbaude automativcally, if it does use it and see if that fixes it if not
your battery is too low
you have a damaged SIIRF chip and that is expensive to repair
Posted on Jun 23, 2009
SOURCE:
My tom tomtom wont pick up a valid GPS signal
Firstly, are you indoors or in a garage? TomTom needs a good uninterrupted signal to get a clean GPS pickup.
Have you done any updates lately as they have a 'GPS Fix' each time which updates satellites and their possible positions?
Sep 23, 2017 | Tomtom GPS
My tomtom wont pick up a valid GPS signal
Firstly, are you indoors or in a garage? TomTom needs a good uninterrupted signal to get a clean GPS pickup and won't work indoors.
GPS is not working. It says waiting for a valid GPS signal. What can I do to fix this?
Usually, when it's waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location. If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
Jan 02, 2011 | Tomtom ONE XL GPS
Tomtom not getting a valid GPS signal. Not picking up any satelitte signals at all.And yes I am outside,and fully charged and keep getting a prompt waiting for a valid GPS Signal.Tomtom is 1 yearand 1...
This is a common issue with TomTom software in general!
To alleviate this issue, Tomtom has released QuickGPS add-on to locate satellites faster. If you have not got it loaded to your device, download the appropriate version of QuickGPS from the TomTom site and make sure you use TomTom Home (connected to the Web and your device) to update both your MAP and QuickGPS on a regular basis.
Hope it helps: let me know how you go and good luck!
Dec 29, 2009 | Tomtom ONE GPS Receiver
Can't get any directions, just keeps on saying "waiting for valid GPS signal" been like this all day. Thanks. Ron
charge it up good for a few hours, preferably the usb cord to your computer, then power it on and take it outside in full view of the open sky and let it aquire the satellites (up to 30 minutes)
if that fails, let me know and we can try a reset and update.
Dec 20, 2009 | Tomtom One XL GPS Receiver
My tomtom one 130 will not pick up a valid GPS signal anymore no matter where I am. It just says: "waiting for a valid GPS signal", even when I know that there is, any suggestions?
Install Tomtom Home on your pc and connect your gps on it.Do not update the firmware yet, but ony the "gpsfix" program. If it does not work, try a reset by holding the power button for 15 seconds.Let´´s get in touch
Nov 20, 2009 | Tomtom GPS
Waiting for a valid gps signal
A couple solutions:
1) Make sure the TomTom can "see" the sky well... the GPS satellite waves are rather weak and easily blocked by trees, and anything not a window.
2) Hook up your TomTom to the computer (see details at www.tomtom.com or in the manual)
2b) Do a "sync" and download all updates. One of the updates is a small file that tells the TomTom where the satellites are located this week, and helps it sync up much faster. The longer time between uses, the longer it takes TomTom to find the satellites, and that can takes up to 2-5 minutes sometimes.
That can be frustrating with a car full of people waiting to get going and the driver doesn't want to drive without making sure the TomTom works and is giving valid directions.
Aug 16, 2009 | Tomtom One XL GPS Receiver
Waiting for valid gps signal
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
Jun 30, 2009 | Tomtom One XL GPS Receiver
Tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
Jun 18, 2009 | Tomtom ONE GPS Receiver
My tomtom keeps saying waiting for gps signal. was working perfectly, now wont pick up signal wherever we are
go to tomtom website ----> support ---->select product,
in the search box type in "lose signal",
click the "2. Updated - No GPS signal"
then follow instructions.
if it help rate the Solution Please
21/Apr/09
Apr 20, 2009 | GPS
Tomtom ONE GPS Receiver Logo
1,563 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
