Question about Frigidaire ATF6000ES Front Load Washer
Bad sound when the washer goes into it's spin cycle
I was doing a load of sheets and when the wash got into the spin cycle, it started making a really loud "clunk/bang" nosie like the basin and or is coming lose and knocking around the inside of the machine. Please help anyone.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Your drum spider bracket broke. You will need to replace the complete drum assembly. The drum assembly will cost about $325 just for the part. If you can replace it on you own it will save you alot of money. To repalce the drum assembly you will need to completely disassemble the machine. If this is the route you want to go. I can walk you thru the process. Just let me know. Jeff
Posted on Jun 02, 2009
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Washer not going in cycles
Where you attached the new hose on the side of the tub, you must remove that hose and insert a small wire in the hole in the cup and clean out the soap scum. Re-attach the hose. Set the washer on spin and run a spin cycle. Then retry your wash cycle.
Make sure the new hose is not pinched anywhere.
Apr 24, 2009 | GE WJSR2070B Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
236 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
