Question about Acer Aspire One Netbook 8.9" Notebook
Connect a printer
How do you connect a printer to the acer netbook
  • ikkenom May 11, 2010
    What manufacturer/model of printer?
    Does the printer have FIREWIRE, USB, or Parallel-port connector?
    Does your computer have FIREWIRE, USB, or Parallel-port connector?
    Did the printer come with a CD-ROM containing software?
    Typically, one should install the software _BEFORE_ connecting the hardware.
  • meteshadow May 11, 2010
    is the printer has usb connection. ?
    Guru:
  • 597 Answers
Buy a printer with a usb port. not the old style printer ports
Posted on Jun 01, 2009
I have been using a Canon MX320 printer with my Acer Aspire netbook for 2 years. It added successfully then using the windows new hardware wizard. Recently the netbook had to go fo "clean up" (virus)
Try to reboot yout computer. And try to disconnect your printer and install again using the Windows new hardware wizard.
If that doesn't work, you can download a driver here and install it manually.
Feb 21, 2013 | Acer Aspire One PC Notebook
I cannot connect to my home network with my Acer netbook.
open your browser go to tools>options>connections(tab) click setup and run through it. let me know what happens. (there's more than one solution)
Oct 22, 2011 | Acer Aspire One Netbook 8.9" Notebook
Need help to connect my acer netbook to cannon printer. already have cable.
First you need to do is to open your netbook on >>> connect the pinter cable to any usb port in your netbook >>> insert the cddriver of the printer in your cdrom or dvdrom device >>>wait for initialization because the cd driver is auto install >>> when promtp >>>click next >>>read the instruction while the sortware installing >>>click next then finish >>>DONE
You may now test to print...
Sep 17, 2011 | Acer Aspire One PC Notebook
Just want ro know what type of printer is compatable with acer aspire netbook? tried 2 types of printers and could not use them. no cd rom
All printers with the right drivers will be compatible with your NETboo, Net book just tells us that you have no optical drive. Any printers website should have drivers available for download, that will configured your pc to your new printer! Just make sure you get the right version, assuming a netbook, you probable have Windows 7 Basic, 32 Bit Operating System! Hope this helps!
Best Wishes and Good Luck!
Apr 11, 2011 | Acer Aspire One PC Notebook
I bought 2 Acer Aspire one netbooks and I can't get either one to connect to wi-fi. They show strong connectivity to the wireless network, but no internet?
you are seeing it strongly connected to the ROUTER---try unplugging the router for a few minutes and plug it back in----Does the netbook "SEE" the network? entered correct ssid? Is the wireless switch enabled on the netbook?
Dec 24, 2010 | Acer Aspire One Netbook
How do I connect my acer aspire one to a printer?
Is it a usb, network, or parallel printer? Make sure you have the correct cord and software drivers. More info would be helpful.
Aug 24, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer can't connect to wireless network
Given the Acer sees the network, the times I have been frustrated connecting a new computer to a wireless network, it's usually been something very simple. I have forgotten one setting, transposed a letter or number. Go back through and make sure everything is exactly right.
Apr 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Is there any way i can connect a HP Deskjet 1600 printer to an acer aspire one netbook?
Assuming the HP printer has a cable with a USB plug on the end of it, then yes you can.
If you are connected to the internet, then Windows (XP or Vista or Windows 7, or whatever operating system you are using) will find the printer (once it is turned on and plugged into your laptop) and it will usually ask you for the printer driver which is on a CD ROM that came with your printer, or failing that it will ask if Windows can go onto the internet and search for the correct printer driver.
If the Acer netbook doesn't find a driver, go to the HP website and download the drivers for that specific printer (ie Deskjet 1600) ensuring you get the drivers for the specific operating system the netbook is using ie get the Vista driver from HP if that is what the netbook is using. Or, get the Windows 7 driver if that is the op system you are using.
Give it a whirl, its not a tough thing to do.
Good luck,
Steve
Apr 09, 2010 | Acer Aspire One PC Notebook
How to install a printer on an acer netbook
Go to printer manufacturers web site download the driver for your printer. place files on desktop, now install the software and follow instructions, it is that easy. OR go to "Printers, Install Printer, and same again, follow instructions.
Feb 27, 2010 | Acer Aspire ONE AOA110-Aw Netbook
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Acer Aspire One Netbook 8.9" Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
