Question about Toshiba e-Studio 232 Black and White Copier
How do I install my scan enabler device for Toshiba estudio232?
I have obtained a memory stick type device for my Toshiba estudio232 copier but it has no instructions with it and the manual is about as much help as a chocolate fireguard! I'm female, blonde and over 40 so need instructions to be made as simple as possible please! I have a similar problem, i go to input the IP address and says conflicting IP address error, where should I look for the IP address. I plugged in the ethernet cord and the orange light flashes but not the green one, i have the usb adapter also plugged in but i do not know the model number we do not have a philips screw driver laying around to get the cover off.
With regard to installing your dongle (i.e. memory stick type device):
on the eStudio 232 there are often THREE USB connectors: 2 type A connectors and 1 type B connector (for information on USB connector types see http://en.wikipedia.org/wiki/Universal_Serial_Bus#Connector_types)
You should try insert the dongle into BOTH type A USB connectors (not at the same time, obviously) to see if the SCAN button is highlighted.
NOTE: your dongle needs to be version GM-2070
I had the same problem with a grayed out SCAN button when I first installed the GM-2070 dongle, but when I inserted the dongle into the other type A USB connector ... VOILA, it worked.
I hope this helps.
Posted on Sep 08, 2009
    President:
  • 2,072 Answers
LOL. Well don't underestimate the over 40 and blond concept LOL.
Anyhow. On the right side of your machine, up and behind the bypass feeder, you will see a small metal cover, very small, held on with one phillips screw. Remove that screw and throw both it and the plate away.
You will see, When you remove the right plate, a USB port, in which you install your Scan Dongle. Yes, toshiba calls it a Dongle. I did not make that up. Make sure you do that with the machine off.
Hey if you have a problem I am going to give you a phone number to call. Call 304-242-1030 and ask for Nils.
He can talk you through it. No thats not me, but it is him...
Posted on Jun 02, 2009
  • Rick Kasper Jun 02, 2009
    Did you get it set up??
2 Suggested Answers
  • 628 Answers
SOURCE: How do I install my scan enabler device for Toshiba estudio232?
What is the model of the usb dongle ? Example: GM1070/1071. By the way, if your E232 is network enable, u can use E-filling features where u store to e-filling then obtain soft copy through file downloader software.
Posted on May 27, 2009
Am looking for toshiba E studio 232
Cartridges have ink/toner? Cartridge bad?
May 26, 2016 | Toshiba E-Studio 232 estudio232
Which model of print scan enabler, compactible for e studio232?
Only this enabler (Printer/Scanner Kit GM-2020/GM-2030) there is no compatible enabler for this
Mar 26, 2016 | Toshiba E-Studio 232 estudio232
Estudio232 error C550
RADF I/F error: Communication error has occurred
between the RADF and the scanner.
Apr 11, 2015 | Toshiba E-Studio 232 estudio232
My internal wireless does not work. Is there another way i can enable wireless? Ive heard about wireless network adapter cards but dont know much about them. please help :)
Other than repairing the internal wireless, obtaining a Wireless USB Adapter is one way to deal with this. (USB must be properly functioning on your notebook of course). These devices look very much like a USB memory stick.
Nov 25, 2013 | Toshiba Satellite L500 Series Notebook
I was scanning documents 8.5x11 into memory stick using microsoft word just stopped error came up 3015 hp laser jet all in one it scans otherwise except to microsoft word
Next time do not scan directly into an external memory device. Scan first into your hard drive and then copy/move it into your external memory device. It puts a kind of stress on the system; it is processing and copying at the same time.
Seems the stress has broken down your memory stick. To confirm if your memory stick is fully functional, check to see if you still see its icon under My computer. If you do try to copy any file into it. If it copies successfully, it means it is still OK. Then scan into the computer first then transfer into your memory stick. If however, it fails to copy, it means the memory stick is affect. Then you need to know to what extent? At least you need to know it you can recover your memory stick.
To do this, right click on the memory stick icon (under My Computer) and select "format." The Format dialogue box pops up. Format the memory stick. If it formats successfully, your memory stick is recovered. But it fails to format, you have lost your memory stick.
Dec 07, 2009 | HP PSC 1350 All-In-One Thermal Printer
May 27, 2009 | Toshiba e-Studio 232 Black and White...
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
1,618 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
