Unit will not come on at all has voltage to unit and to contactor?
Came home last night and found unit not blowing cool air just luke warm air. thought it might be iced up so turned off and let sit over night still no good, opened unit up and found Wires were burnt on the Contactor replaced them, prior to this the unit had seemed to blow less cool air than before. Now the unit will not even turn the fan on let along the compressor and coil fan????
  • 21 Answers
Redchris652,First of all,do a visual inspection of all the wires(no shorts or grounds)..The way you are describing the problem,I would suspect the transformer,which is ually located in indoor air handler unin.Back up a minute.do you have 240volts coming in to the airhandler?If no check the breaker.I like to start at the easiest place.There shoud be 240v coming in on the primary of the transformer ang 24volts off the secondary,this is the control voltage.You can always check the transformer by going in,turning the thermostat completey off and then turn indoor fan to the "on" position.If it comes on, then the transformer is good .But again,make sure you have 240v to primary.Withouy 240vand 24v nothing will work.If you manually push in the contactor will the unit run? Yo u said the unit had stopped cooing as it should,this can indicate a low refrigerant charge.Some uuits are equipped with a low pressure and a high pressure switch switch.These are safetys.At a certain low pressure,the low pressure switch opens the low voltage circuit to the contactor,nothing will work.High pressure switch,if pressure gets too high,nothing works,this is when head pressure gets too high.Hook up a set of guages to refrigerant lines,see what the pressures are,low pressure should be a full scale deflection.If you want to see what pressures are,manually push in contactor and watch pressures.Watch your fingers!If pressures are low,add freon.til low pressure switch resets,the unit will put 24v to contactor and unit should run. chech for leaks,and recharge
Posted on Jun 01, 2009
  • 142 Answers
Sounds like you lost the refrigerant charge. Low pressure switch will not let compressor run. Look for oil around the condenser tubes. If you find it, this is probably the leak source.
  • George Fleming Jun 01, 2009
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
Outdoor a/c unit is cyclying on and off, not
Check the contactor at the outdoor unit. Look for burnt/pitted contacts. Replace if necessary and test your system again with the new contactor. If your contactor is okay, do the following:
When the unit shuts off, test for 24volts at the contactor coil. If 24 volts exists, test for 240volts on the LINE side of the contactor. If you have 24volts coil voltage and 240volts LINE voltage with the unit not running, the problem will be your compressor contactor or a wiring problem (should be evident with visual inspection). If you have 24volts coil voltage and no 240 volts, then you have an electrical problem (loose wires/connections) between your main circuit breaker box and your A/C. If you do not have 24volts coil voltage, then you have to determine why........try jumpering Y & R at the indoor unit (put fan in ON) and see if the unit runs continuously. If it does, the problem is either your thermostat or Y wire between your t-stat and indoor unit. If it does not run continuously, then the problem is in your wire between your indoor unit and your outdoor unit.
I hope you find this information to be very helpful to you moving forward. :-)
Apr 08, 2010 | Heating & Cooling
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
nope, nope, sounds like a stuck contactor in the electrical compartment of the condenser, but there are actually several things that could cause it.
Sep 30, 2009 | Heating & Cooling
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Coleman evcon air unit keeps blowing the three amp fuse
BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU! That said, it sounds like you have a short in the control (24VAC) curcuit to the condenser. A mouse probably made a home in the control compartment of your condenser. BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU!
Apr 25, 2009 | Coleman Propane Forced Air Heater...
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
337 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
