Question about Garden
Weed Eater GTI 15 won't run???
My 10+ year old grass trimmer won't run. I can pull start it but it won't stay running after the first few seconds. I followed the owners manual and replaced the fuel, checked the plugs, cleaned the air filter, and cleaned the muffler. I then tried adjusting the fuel mixture and idle screws with no luck. Any suggestions? It seems to die the quickest when I tip the trimmer head downward for use and give it gas.
Thanks,
Joe
    Sergeant:
    Champion:
  • 223 Answers
Check the gas lines, one might be bad...
Posted on Jun 01, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed Eater GTI 19T
    If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
    Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Craftsman 32cc gas trimmer won't start.
    Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
    Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
    Toro weed eater starts but then stalls out
    A few things to check, clean or replace:
    • fuel filter - located inside the fuel tank
    • Spark arrestor - located at muffler
    • Spark plug
    • Carburetor
    Mar 08, 2014 | Garden
    Hard to start weed eater
    check for proper starter proceedure.some models are very specific to starting proceedure.if the equipment does not run to warm up or if the chike sequence is improper it will not start
    Sep 09, 2012 | Stihl FS 85 Weed Eater
    Husqvarna weed eater starts , but blows alot of smoke & then stalls out
    Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    String Trimmer Starts Then Stalls
    My String Trimmer Starts But Won Stay Running
    Craftsman Trimmer starts then dies
    How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
    How to Clean Two Cycle Two Stroke Engine Carburetor
    Sep 06, 2012 | Husqvarna 128 LD Weedeater
    Cutter runs for approx 10- 20 min and cut off and have to cool down before it starts again.
    Hi, have you ever cleaned the unit out? If you have air pressure available, this is the easiest way to do it. Blow all the old dead grass, weeds ect out from the engine area of the Weed eater. If you don't have or have access to a compressor, take the unit to your local garage/service station and ask to use their air, or ask them to blow it out for you. This alone may cure the problem. However the proper mix is critical for proper performance also. If the mix is too lean the unit will over heat. Clean it out, and be sure of the mix ratio. You should be 'good to go'. Good Luck Vern
    Jan 30, 2012 | Stihl FS 85 Weed Eater
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Weed eater GTI 17 won't run on high speed
    A couple of things may work...
    Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
    Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
    May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
    Garden Logo
    849 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
