Question about Xerox Phaser 7700 Laser Printer
Streaking Printer We've been getting colored streaks down the sides of our pages. Used to be yellow streaks, now they are cyan streaks. What can we do to fix this problem?
  • 208 Answers
Re: Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Posted on Dec 20, 2007
0 characters
3 Points
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Streaks on left side of paper when printing in color
go to the control panel and then printers and fax. double click your printer and click on the tab and button to "clean print heads". after doing this, click on "align print cartridges". this will fix the streaking problem you have
Feb 25, 2009 | Dell 5100cn Laser Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Dell 3010CN Color Laser Printer is leaving vertical smudge/bleeding. Is there a toner dump box to empty? It is just cyan streaking.
Try a new Cyan toner cartridge. If nogo, will need a new transfer roller or transfer belt (I used to work on these printers but forgot if they use a belt or not... I will check on the DCSE site and post back)
Jan 05, 2009 | Dell 3010cn Laser Printer
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at:
and parts purchased at:
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Nov 22, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
1,032 people viewed this question
Top Xerox Printers & Copiers Experts
Level 1 Expert
Patrick Carmichael...
Are you a Xerox Printer and Copier Expert? Answer questions, earn points and help others
