Question about Canon Office Equipment & Supplies
How to remove the foam packing on print roller.
Spotted an upward arrow on the plastic cover, and then felt at ease with applying strong pressure with fingers to move the piece upward and out.
i must confess that the packaging did contain a tiny paper diagram of performing this process (which i eventually found later) that was a separate paper and easy to overlook.
Posted on Jun 02, 2009
Dirty printing
heater unit roller. If roller became old or stitch toner on it, something small scratches. Check it for replacement.
Dec 07, 2013 | Office Equipment & Supplies
Phaser 6180 prints little black smudges on every page, spaced exactly across and down page
These will probably look like a little squiggle.
They are cause by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Sep 06, 2013 | Xerox Phaser 6180N Laser Printer
Xerox 6180mfp repeating pattern
They are caused by a component in the toner cartridge.
Nov 15, 2012 | Xerox Phaser 6180N Laser Printer
Error code 5C00 what is this and how do you repair this erroe
This error is shown when there is any kind of foreign material or packing material stuck inside the printer which restricting the printhead to move freely. To resolve this issue, please follow the instructions mentioned below:
1) Confirm that the printer is powered off.
2) Disconnect the power cord from the printer or at the wall outlet or both.
3) Open the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray. If that is the case, please refer to the illustration in step 3 to ensure the white foam piece is removed along with the protective tape. skumar_sreen.gif
4) Pull the orange protective tape (A) and remove the white foam (protective material) (B). skumar_sreen.jpg
5) If the the white foam was not removed along with the orange protective tape, check for it on the right, inside the printer. a) With the printer powered off and unplugged, slide the print head carriage to the left. b) Looking inside the printer from the left, locate the white foam in front of the purge area. Note: It is recommended to use a thin latex glove as there may be ink mist on the white foam or surrounding print area. skumar_sreen_0.jpg
c) Cautiously remove the white foam with your hands. Be careful not to touch any other components in the printer.
6) After removing the packing material, look for and remove any other paper debris or foreign objects from the extreme left and right sides of the carriage area.
7) Close the scanning unit cover.
8) Reconnect the power cord and then power on the printer.
Aug 30, 2011 | Canon MP560 All-In-One InkJet Printer
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
BLACK PRINT IS VERY FADED ALTHOUGH TONER HAS RECENTLY BEEN REPLACED
when u take out the toner cartridge u will see a foam roller ....with a key take out the roller( notice how it is positioned you will have to reposition it) take the foam roller and run it through a clean sheet of paper a few time you will see how the paper dust will start to come off. do it a few times the roller should appear darker, pop it back in and youre set. you are welcome :o)
Dec 17, 2009 | Xerox Phaser 6110 Laser Printer
Prints a black line down the my CD
check your plattern foam thingy (not the official term but close) thats the foam membrane that absorbs ink on boarderless printing etc, could be that the cd tray is acting on the foam if is a little lifted or displaced. but just a thought, never seen it happen like this before.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
All that foam packing inside Kenmore 75050 air conditioner
make sure what you're calling foam packing is not in reality foam insulation. If that's the case you'll ruin your unit by removing it. It would be pretty unusual for packing to be placed inside the unit.
Aug 07, 2007 | Kenmore 75050 Wall/Window Air Conditioner
64 people viewed this question
old marine
old marine
