Question about Vacuums
I have an Electrolux Commercial Upright vacuum Model U129C. It has a device which turns off the motor driving the beater bar if something gets stuck in it. There is a simple reset button to restart the beater after clearing the obstruction. Just recently on flat dense low pile surfaces the switch cuts in after just a few seconds and turns the beater bar off. This doesn't happen on high pile carpet but the motor doesn't quite sound normal. There is no obstruction - the beater bar can spin freely when disconnected from the belt.. The motor still works but seems to sound a little slower and more labored. If the beater head is lifted off the carpet it works fine but cuts out as soon as it is lowered onto dense carpet. Is this a motor problem? ie motor is running too slow so as soon as the extra friction of running on dense carpet happens it triggers the safety device?
  • aday712 Jun 01, 2009
    Thanks. I don't want to buy a new motor if that is not the problem (obviously!)
    The question is how does this cut-off switch work? ( the one that shuts off the beater bar if obstructed). My theory is that it works off engine rpm - so when this drops due to obstruction then it shuts the motor down.
    So in my case it seems that the motor under no load is beginning to 'die' and so is already running at too low a speed - so with the drag of running along tight piled carpet the rpm quickly drops further and reaches the critical level shutting the motor off.
    Is this explanation likely?
    Or could there be another way that the cutoff switch would work? necessitating replacing some part other than the motor?
    Alan Day
  • aday712 Jun 04, 2009
    The basic question is how does this cutoff switch work? 2 suggestions so far
    1 - motor problem - motor failing - rpm dropping - so resembling condition of obstructed beater bar
    2. Low voltage. Meaning house voltage is temporarily low? Or some circuitry inside is malfunctioning? In nay case how does low voltage explain the normal function ie how the switch cuts off the motor when beater obstructed?
    Any other ideas?
  • 374 Answers
The motor is having a problem.There might be two reasons...either the coils inside it got heated up which will be needing rewinding or you can buy a new motor or there r capacitors attached sometimes u can make a check on that also if that's gone Kaput.
Posted on Jun 04, 2009
  • 749 Answers
It seems like the motor needs replacing if its making the noise, repairs will be expensive.
Posted on Jun 01, 2009
  • 421 Answers
Sir this is not vaccum cleaner problem it is problem of low voltage
Posted on Jun 02, 2009
Tip
Burning rubber smell from your vacuum?
Drive belt is slipping.
Remover cover from the bottom of the power head or base if upright style. Usually just 2 to 4 screws.
You will see a belt (thick rubber band) connecting the beater bar (roller with brushes) to the motor. Remove the beater bar and belt. You do not need to remove the motor. The beater bar will be held by clamps and screws. Remove the screws and clamps and lift the beater bar directly up.
Take the belt to your local vacuum dealer (note make and model) and get a replacement.
Installation is the reverse of removal.
Note: you will find a lot of hair and junk twisted around the beater bar. Take the time now to cut it all off.
Hope this helped. Please rate this if it helped you.
on Mar 07, 2010 | Vacuums
Replaced drive belt for beater bar, but now beater bar motor will not engage/turn on.
The most likely problem is something was not put back together properly in the clutch. You can move the belts by hand with the clutch out of the machine. Move the motor belt and switch the lever off and on and see if the brush belt is turning on and off. It not you will need to take the clutch apart and reassemble it. Test it before installing.
Sep 10, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater not turning but belt good. beater motor not turning but turns manually
Hi Dan:
check both ends of the beater bar. Pet/Human hair, thread, strings and even dirt can really get wound up in between the plastic ends and the bar. It might look ok but it won't turn effortlessly. If you find that is the case, you might be able to fish the junk out but from experience it's just better to buy a new beater bar or roller part.
Mar 12, 2011 | Electrolux EL8502 Versatility Bagless...
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
Beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Mar 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Vacuums Logo
252 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
