Question about Sony MDS-JE520 Mini Disc Player
Stuck disc i have a Minidisc player,which has a disc stuck in it.It will not eject,and just keeps reloading.Any ideas
  • 4,234 Answers
The carriage assemblies for these units are known to break. Please DO NOT attempt to remove the disk. Bring this to an authorized Sony service center. They should be able to give you a fixed price repair quote. This is the only way to save the disc and prevent further damage to the assembly. The replacement assemblies are a bit better than the originals so you shoudn't have this problem again.
I have repaired a number of these with much success. Care must be taken so that the disc heads are not damaged.
Keep us posted.
Dan
Posted on Jun 01, 2009
Minidisc will not eject
Try unplugging it and plugging it in the next day. It sounds bizare, but it works for me.
Jun 04, 2014 | Sony MDS-JE440 Mini Disc Player
Sony minidisc will not eject discs
This could be a worn out loader. I've had bad luck with push in to load decks since I push them in too hard and wear them out, I migrated to tray loaders for this reason (I have a JA50ES and a JA20ES) which like other high end MD decks have a try which opens up to accept the disc.
The mehanisms wear out and are not worth fixing. I paid a pro $350 to fix a JA3ES a few years back and it only worked for a short time. I'd simply try to find a replacement deck rather than spend too much time or trouble on it. The 510 and 520 are great decks but getting very long in the tooth like me...
Apr 22, 2014 | Sony MDS-JE520 Mini Disc Player
What does "eject error" mean?
Your MD Recorder/Player has a stuck disc or cannot eject it properly. Basically it is not handling the disc safely and it may get snagged or damaged as a result of a physical mechanism which is not working correctly - out of allignment or worn out by people shoving discs into the machine or just plain old age on these units.
Feb 13, 2014 | Tascam Cd-rw900sl Cd Recorder/player
MDS-E10 failed to record
If you recorded a disc and then the deck saved it; then you cannot play it is probably a bad mechanism. When I buy old decks I check them by inserting and recording a disc then ejecting it. If it will then not play when reloaded the deck is bad. Often the decks say they are saving but are damaged and cannot so this is the only way to know for certain.
Jan 27, 2014 | Sony MDS-E12 Mini Disc Player
Disc is stopped and ejected prematurely
I've never had this happen. I'd try another disc if it is OK it is probably the disc if not I fear the mechanism is getting worn out. Make certain your mechanism is clean I seldom use the cleaner discs but in this instance I would run it if the problem persists. Using the cleaning discs too often is not a good idea. I've used compressed air to blow out a hair from the mechanism which was messing with the laser in a similar cirsumstance.
Sep 13, 2013 | Sony Minidisc Deck Mds-je510 Recorder
Disc stuck in machine will not eject can hear motor running but no response
take off cover.Then carefully by hand move plastic gear wheel at back of mechanism.
Oct 18, 2010 | Sony MDS-S40 Mini Disc Player
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
439 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
