Question about Philips 50PF7320A 50 in. Plasma HDTV
Blinking red lights
I have a 42 inch philips plasma w ambilight and the tv wont turn on. it has 7 blinks of a red light wen i attempt this. This happened a few weeks ago and we tried pulling cords out of the back etc.. and unplugged it. It ended up working all of a sudden for a few day and now it wont work again... any help would be greatly appreciated. Scott Blinking lights. What the heck does it mean?
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
I'm having the same issue on the 50". I don't know anyone that can solder, is that difficult to do?
Posted on Jul 28, 2009
  • b530 Jul 28, 2009
    Oh and mine actually blinks 6 times before blinking rapidly 3 times. What does that mean?
Same issue here, 7 blinks. Thanks to "stampco8" 's solution, followed instruction and got the tv fixed. The two 3300uf 10v radial capacitors were bulged, which is an indication of bad capacitor. Found a local electronic warehouse sales the capacitor at $1.50 each. I bought the power supply unit with me to the electronic warehouse and have them check out the fuse, but I only found 4 fuse on my unit. All the fuse are still good and working. Then I removed the bad capicitors and solder on the new ones, install the unit back in tv, power it on and it WORKS as new!
$3.00 and a couple hours of personal labor and got the problem fixed. Thanks again to 'stampco8' detailed solution!
hint,
* I have nothing against radio shack, but they don't seem to carry the capicitors needed. I search on their site and visit a couple of their retail shops with no luck. But the clerk at the rado shack store's were very helpful. Advised me where to find it locally.
* If you don't know how to operate a multimeter, don't mess with it. Have a knowledged person check out the fuse for you.
Posted on Jun 25, 2009
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My 50 in philips ambilight plasma will not turn on and blinks a red light 7 times and repeats
The failure with your plasma is with defective capacitors in the power supply.
Check the link below with info on how to DIY.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Jul 16, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
My TV will not turn on. Power light is blinking
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Philips 42'' flat screen
Bring your TV to eletronics technician. The main power of your TV has a broken semiconductor parts that need to be replace. ( Maybe power mosfet, fuse, transistor, capacitor, etcc ).
Jul 23, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Philips 50PF7320A 50 in. Plasma HDTV Logo
906 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
