Question about Vizio P2 42 in. HD-Ready Plasma Television
Vertical Red Line
I have a Vizio Model 42HDE TV.  It has a bright vertical red line about an inch wide, on the right hand side of the screen.  It occurs on all inputs and channels.  Does anyone know what causes this?  Thanks.
  • 4 more comments
  • lite2 Nov 14, 2007
    Yep, I got that too. Same model set but my lines are always to the left half of panel and can be anything from a hairline to 1"+ wide and red or green. Only does it every month or 2 and a slight knock on the frame fixes it till next time. Happens on ANY source. Also my DVI stopped working the 2nd day I had it. Its connected to my PC (MCE2005) so for now I have to use the VGA in.
    Waiting on a service call before the ext warr. expires. Hope they just replace the whole thing.
  • Ironbag Nov 24, 2007
    Same problem here. Ours come and goes. After two hours of use it disapers just for a couple of hours then it will come back. Talk to Vizio customer service they say to junk it, bad display.
    I got the feeling is something minor and I refuse to depart with it.
    Any useful ideas?
  • kelso123 Dec 04, 2007
    Had the TV on the wall attached to an HD box. When I took tv down and set it up in another room attached it to a cable wire ( no box). When I turn on the tv I have a red vertical line if you are looking at the tv on the left side. Manual says it could be a bad VH cable connection. Do I need a cable box?
  • Anonymous Dec 10, 2007
    I have a orange/pink line (2 1/4") inch wide (4 1/4") from right side of screen. Line shows when no devices are connected to it. I tried to correct it by disconnecting all devises to it and nothing works. Please help!
  • algeo Jan 03, 2008
    I have a vertical orange/red line about 1" wide, 1" in from the left side of the screen. Vizio says it is the video board. $150 for board, $195 for them to come out for service. I had drop outs occasionally with this vertical line since I bought the tv three years ago (1/05) and about month ago the line became semi-permanent. I googled the part number and some websites (shopjimmy, tv replacement parts on e-bay) came up with used parts but not the video board I need. Any alternatives, suggestions, etc...
  • Anonymous Mar 17, 2009
    6781QCH060Q (060Q) will this board work for a 37" vizio lcd hdtv
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 87 Answers
It is very likely you have a bad display.  One way to confirm this is pull up the menu and see if the red line is on top of the menu or not.  If the red line is on top of the menu the display is almost certainly the cause.  If the red line is underneath the onscreen display you likely have a bad logic board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
    New Friend:
  • 22 Answers
Fixed!
Spoke with PartStore.com, rep stated 6871QCH038C (038C) is the superceded replacement for the defective prone OEM 6871QCH038A (038A). They and others offer the 6781QCH060Q (060Q) for $50 - $100 more. I opted for the 038C, but I was concerned about the title of the part which states "HAND INSERT"... PartStore.com rep stated it is in fact a board and there is no soldering needed, just "plug and play". DONE, paid only $120.95 + next day shipping for $29.95.
Since I took the TV apart before, it was a breeze and took about 2 hours, start to finish.
Important note, remember to remove the two 1" square spunge type heat sinks/pads the new board needs those for a proper installation and protection of the certain component.
Also you need two small zip ties to replace the ones you are going to clip off.
Added Bonus, the new board fixed other issues:
1. At times I would get a squeegly red line go across the screen. I thought it was the source (cable) but it is gone now.
2. Screen Shift, when I use the XBox for Games or DVD/HDVD the screen would shift. Very annoying, prior to swap out, recently the screen started to shift watching cable. Now it is no-longer an issue.
I am really pleased with my DIY repair and wanted to share.
The damn Vizio Out of Warranty Service wanted $360 for a service call which included the part for $125 plus they take my bad board for exchange.
6871QCH038C $120.95 http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenit h/6871QCH038C/New.aspx
Over Night Shipping #29.95
Posted on Dec 31, 2008
I have a VIZIO P42HD as well. It was manufactured in 2004 and has a serial number of DTPBBT AE501351. I started with a red verticle line on the right side of the screen. This eventually led to a green vertical line on the left side and finally ended with the left half of the picture going out. I followed the "Best Solution" at the top of this thread, including ordering the part overnight from PARTSTORE.com. I ordered part #6871QCH038C as well. The part actually says its for an LG so I was a little worried. I called VIZIO and they could not give advice since I was dismantling the TV, but I went for it anyway. Low and behold, when I took it apart the PCB assembly was made by LG even though it was a VIZIO TV.
I took the TV apart, replaced the PCB assembly and it all worked flawlessly. Total time was about one hour. I have ZERO experience with TV's and was very impressed at how well it all went together.
Posted on Feb 16, 2010
I did have 1 inch black line starting from top to midle of screen.I talk with visio without any result. I did open tv (pd42hd SP42A type). I carefuly open flex connection when screen connect to pcb where black 1" band show. On one connection there are three square chips. Each of them have e big smt resistor. From hot solderin on resistor was fragile. After I resolder this resistor 1" black band went way.Hope this will help.
titikrojana@hotmail.com
Posted on Dec 04, 2007
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Aug 30, 2009 | V, Inc. Vizio L6 HDTV-Ready LCD Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical red line on my Vizio plasma
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Feb 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Vizio P2 42 in. HD-Ready Plasma Television Logo
4,754 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
