Reference to Digital Multifunctional System Copier Model Al-2030. The auto function copies too light and dark shadow lines appear across the page about 3.5 inches wide.
    Brigadier General:
  • 3,917 Answers
Try print from a pc, if those lines still appear then you should replace the drum unit. If not then clean the copy glass and the scanning mirrors.
OR
Something might be blocking the light from the scanner lamp to fall on the originals. Try cleaning the glass covering the lamp.
Check the paper sensor and the feeder mechanism
Thank You
Posted on Jun 01, 2009
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Squiggly lines on copies
THE CARTRIDGE PORES ARE PARTIALLY BLOCKED USE FORCED COMPRESSED AIR TO OPEN OR BLEED THE PORES AND THEY WILL WORK FINE
Jul 19, 2013 | Copystar CS-1620 Copier
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Dark horizontal lines appear across copies
This is usually caused by a dirty main charger grid, try cleaning it per the instructions in your operators guide. If you don't have the guide you may be able to download one from the Minolta Website at
http://kmbs.konicaminolta.us/content/support/supporthome.html
Sep 04, 2009 | Minolta Di151 All-In-One Laser Printer
1/8 black lines on Sharp AL-1631 copier
Have you cleaned the narrow glass next to the platen where the originals are scanned across when using the auto feeder?
Feb 17, 2009 | Sharp AL 1631 Copier
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
I have not recieved any assistance yet.
I will attempt to help you with your problem. Keep in mind that I happend upon this post and I have absoultely no idea what has transpired before this contact with you today. Hopefully I can resolve your situation.
The CS-2030 does NOT come with a duplex unit as standard equipment. If your unit does not have an AD-61 duplex unit attached you will not be able to perform this function automatically. You can, however, use the bypass tray to reinsert the copy to ad a second side image. If you can tell me for certain that your unit is equipped with a duplex unit I will be glad to research your issue futher.
Jun 03, 2008 | Copystar CS-2030 Copier
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Feb 15, 2008 | Copystar CS-2030 Copier
20 people viewed this question
jasbo
jasbo
