Question about D-Link AirPlus DI-524 Wireless Router
Getting a validating identity message that stays there for minutes then I get little or no connectivity. Using WPA-personal with a 12 character password
Getting a validating identity message that stays there for minutes then I get little or no connectivity. Using WPA-personal with a 12 character password. My other devices, IPOD, IMAC, Iphone all connect to the network but my XP laptop will not. I have it set up to accept WPA and entered the password but no connect
  • torracar Jun 01, 2009
    no i am actually sitting within 15 feet of the router so it is not a little or no connectivity problem although I do get that time out.  It has to be a security thing, my other computers and devices will connect just not the XP machine.
    Guru:
  • 597 Answers
I think the problem is the little or no connectivity. If you're not getting a good signal the verification process with your WPA and password is timing out before you can get verified. You probably need to turn antenna or get less blockage between you and source before trying.
Posted on Jun 01, 2009
  • obwhon Jun 01, 2009
    I'm wondering if there is another or previous connection interfering. Go to Start >All Programs>Acessories>Communications>Network Connections and disable all connections by right clicking each of them and hitting disable. Then reboot the computer. This should reset your ip address to default and you shouldn't be trying to log into anything when you reboot. Then trying once again to log into your wireless and enter your password information.
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
Can I change my security from WPA PSK RADO TYPE 802.11 N to WPA2 PERSONAL. WHich is the most secured - yes? Or do I have to re-install the entire software? Thank you
You can switch the security type at any time, but of course you will need to set all the wireless workstations to the new security type as well.
Also be aware that WPA2 is not supported properly, well, or at all on some network cards, and you may find that some devices will connect and others will not.
Honestly, WPA is very secure in your passphrase includes caps, small, numbers and at least one special character such as * or ? or or some such thing.
Also, if your passphrase is or contains a "non-word" like RaUoip or other nonsense that never appears in any known dictionary, you can bet nobody will take the years it would take to crack your WPA passphrase through brute force!
If you aren't currently using WEP (I can crack a 26 digit [13 hex digit, 26 character] key in as little as 8 minutes) then I really wouldn't bother changing to WPA2.
Jun 24, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I forgot my pin so how do i login another pc in my home
PNI is short for personal identification number. In most places it's a 4 character password that is numbers only. It doesn't apply to routers, but PASSWORDS do. A Netgear, most notably the 614 you asked about in another question has TWO, one for logging into it, and one that is set up for wireless security. By default the username=admin and the password=password for a comper connected to the WIRED port of a router and on the same network. That's how you access the webpage that lets you see or created an SSID (the network name) and wireless password if it's a secure login.
Those passwords depend on what type of protection you have. In WEP, you can have either a 10 or 26 character HEXidecimal password. That means, not case sensitive and using the numbers 0-9 and letters A-F (base 16). For example 0102030405 is a valid WEP password, so is FACE123456.
If you use WEP, that password key is visible when you log into your router and click on the wireless settings tab.
If you are using WPA-PSK security, you can use an 8-63 character ascii (regular letters and numbers)...but it's case sensitive and you can't see it when you log into the router. Netgear1 and netgear1 are valid passwords, but not equal. If you're into punisment, you could also type 64 hex characters exactly as a WPA password :-)
Last, but not least, you could reset the router and start over. On the back of the box, where all of the calbes come out, to the right of the 5th jack is a group of holes. On of them hides a reset switch. Pressing it in an holding it for about 15 seconds will restore the router to factory default. The default address is 192.168.1.1 and you have to use a wired connection to gain access to the router because there is no wireless. The username and password is also defaulted.
Carl
Feb 26, 2011 | NetGear Computers & Internet
How can I validate my identify with D-Link-N router? Thanks, Monique
Are you trying to connect to the wireless network on Windows XP.
If you are getting the error " validating identity " Then there is a problem with the wireless conenction.
You can try to add the wireless network manually.
Or if you are using the security type WEP then WPA.
then try to connect.
Click Here for more information about the routers and network
Aug 21, 2010 | Computers & Internet
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Aug 02, 2010 | Computers & Internet
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Wii Console: error message given when trying to connect error ...
Error Code: 52032 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
May 16, 2010 | Nintendo Wii Console
Secure network
Normal 0 You should use the strongest form of encryption that all of your wireless devices can support. If they can all do WPA2, then use WPA2. Otherwise you can use WPA.
With WPA or WPA2 you should also use a strong key (sometimes called password or passphrase).
To set up wireless security, you must use a computer that is wired to the router.
Where to find the router settings: The other settings are all found in the "Wireless" or the "Security" section of the router's setup pages, located at 192.168.1.1
First, give your router a unique SSID. Don't use "linksys".
Make sure "SSID Broadcast" is set to "enabled".
Next, leave the router at its default settings (except for the unique SSID), and then use your pc to connect wirelessly to the router. Test your wireless Internet connection and make sure it is working correctly. You must have a properly working wireless connection before setting up wireless security.
To implement wireless security, you need to do one step at a time, then verify that you can still connect your wireless computer to the router.
Next, encrypt your wireless system using the highest level of encryption that all of your wireless devices will support. Common encryption methods are:
WEP - poor (see note below)
WPA (sometimes called PSK, or WPA with TKIP) - good
WPA2 (sometimes called PSK2, or WPA with AES) - best
WPA and WPA2 sometimes come in versions of "personal" and "enterprise". Most home users should use "personal". Also, if you have a choice between AES and TKIP, and your wireless equipment is capable of both, choose AES. With any encryption method, you will need to supply a key (sometimes called a "password").
The wireless devices (computers, printers, etc.) that you have will need to be set up with the SSID, encryption method, and key that matches what you entered in the router.
Retest your system and verify that your wireless Internet connection is still working correctly.
And don't forget to give your router a new login and password.
**Picking Passwords (keys): You should never use a dictionary word as a password. If you use a dictionary word as a password, even WPA2 can be cracked in a few minutes. When you pick your login password and encryption key (or password or passphrase) you should use a random combination of capital letters, small letters, and numbers, but no spaces. A login password should be 12 characters or more. WPA and WPA2 passwords should be at least 24 characters. Note: Your key, password, must not have any spaces in it.
Most home users should have their routers set so that "remote management" of the router is disabled. If you must have this option enabled, then your login password must be increased to a minimum of 24 random characters.
One additional issue is that Windows XP requires a patch to run WPA2. Go to Microsoft Knowledgebase, article ID=917021 and it will direct you to the patch.
Sadly, the patch is not part of the automatic Windows XP updates, so lots of people are missing the patch.
Note:
WEP is no longer recommended. The FBI has demonstrated that WEP can be cracked in just a few minutes using software tools that are readily available over the Internet.
Aug 03, 2009 | Linksys Wireless-G Broadband Router
Can't connect with microsoft MN-510 using WPA
This means that you have to enter the network key into your computer in order to connect to the network,
If you enter the password as hexadecimal characters, you must type exactly 10 characters (5 bytes) for a 40-bit key (valid characters are 0-9 and a-f), or exactly 26 characters (13 bytes) for a 104-bit key.
If you typed any number of characters other than 10 or 26, or any character that is not a hexadecimal digit, this is interpreted as ascii string.
In this mode, each character is a byte by itself.
So, valid length of the string in this case is either 5 or 13 characters.
If this condition is not met, the string can't be accepted as a valid password.
Please check carefully what you type. (Letter O instead if zero, or small L instead of 1 etc.)
If you don't know the key, you have to connect to the router via a cable and copy the key from there - or ask your Dad to give you the information. He will have it, because he has a working connection.
If you have any more questions or this is not clear ot you, just come back here and leave a comment - I'm happy to help.
May 29, 2009 | Microsoft Broadband Networking MN-500...
D-Link AirPlus DI-524 Wireless Router Logo
429 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
