Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Paper Size Error: The specified custom paper size is not supported in the selected tray. I have a Hp Officejet pro L7780 All in one. I checked the default printer and paper handling and it all says letter for the paper handling but when I try to print a page from online it comes up with the paper size error
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Posted on Oct 20, 2009
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Tray 2 Printing
Couple of things for you to check out.
1. Is that you've enabled the second tray for the printer. This is normally automatic but to check go to:
START > Printers > L7780 > Properties
- Click the "Device Settings" tab
... then sort out the different setting so they are all correct such as paper size and of course "Tray 2: Installed"
2. The other more common issue is simply that the printer isn't sitting properly on top of Tray 2 and as a result it's not engaging the cog wheel properly to pick up paper.
This is one of those trial and error things where you pick up the printer and re-slot it down onto Tray 2 until it works properly.
Hope that helps...
May 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer continues to indicate "out of paper" even after reloading and pressing "ok".
Check the paper tray - there's a "stop" that keeps the paper snugly in the tray. Make sure this stop is set on the proper paper size and isn't sliding when you put the paper in. That should solve it!
Apr 17, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Copier will copy regular paper but won't copy legal size paper and take paper from 2nd tray!!
I can't help with the legal size issue as I've none to try with here but the 2nd tray I can help with.
Most of the time the problem with tray #2 is that the printer hasn't quite sat properly on top. Try lifting the printer up and shifting the printer about a little so that the gears mesh better... You may need to repeat a couple of times but this usually sorts the issue.
You'll also want to make sure the paper in tray #2 is not help too tightly by the paper guide and if you can fan apart the paper to get some air in between the sheets.
Hope this helps...
Mar 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hp 6310 officejet
Check the paper size setting when you set up the printer. Check page setup in File menu and specify the page size.
Dec 01, 2008 | HP Officejet 6310 All-In-One InkJet...
I need my HP Officejet Pro L7780 all in one to pull either legal size or standard size paper, it will only pull standard size, I have two paper trays
In your print queue under device settings, you have to tell the computer that your using legal paper and in which tray.
You can permently set it like this....
Start > Control Panels > Printer and Faxes >
Right Click on the Printer Icon > Properties > Device Settings
and choose the Tray and assign the Paper Size.
If the tray is not selectable, look in the same area for Installable Options and set the tray as installed.
Within a program you can do it on the fly one time like this...
File > Print > Properties > Advanced > Paper Size
But, the paper must be in a default tray for this mode.
This info may vary for different printers and applications.
Nov 19, 2008 | HP Office Equipment & Supplies
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Unable to get faxes to print to legal size
here are the steps that i want you to follow inorder to use the tray for legal size.
1. On your printer itself, Press the SETUP BUTTON.
2. Scroll Down, and look for the option "Preferences", then press okay.
3. Scroll down again, then look for Tray Lock, and press okay.
4. Under Tray Lock, you will have an options there;
- Tray 1
- Tray 2.
5. If you are using the legal size paper for tray 2, then choose Tray 2 and press okay button to apply. And if you are using the Tray 1 for the legal size, you can go ahead and choose Tray 1 and press okay to apply. And this should work.
If in case you still have issues setting it up, please inform me.
thank you so much.
adonscott
Jul 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
3,785 people viewed this question
Seeker5211
Seeker5211
