Question about Mtd FASTATTACH MANUAL SLEEVE HITCH
Replace transmission belt on my 42" MTD Mower
The transmission belt jumped its pulley and is riding against another belt. How do i fix it and where do i get a service manual?
Have a Stanlet model number 309311x692 looking for diagram on blade belt
Posted on Aug 27, 2009
  • 45 Answers
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Posted on Aug 25, 2009
MTD 42" zero turn transmission belt jumps left pulley on start
A little wd40 on each pulley arm assembly, make sure they move freely and good time to check the belt and belt brakes if equipped.
I assume your belt was recently removed or installed and is not following the correct pattern. Is this the issue ?
It's very common for people to install their belt around pulley in different direction and belt is not ( or is ) riding on the Idler pulley, other, or guides incorrectly.
Under the chassis somewhere is a label for belt pattern and is usually under the left side foot grip of the chassis.
( Lifting the mower ? )
Be sure to have some chunks of wood available. I use 2x4 and 2x6 scrap to hold up the machines without use of jackstands or any jack which causes damage.
Jul 07, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
1997 MTD Riding Mower 18hp 42"cut. Drive belt
I wish to tell dwhandys that this is a great answer, and a great solution. You surely know how to work!
Sep 03, 2011 | Yard Machines Garden
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
After replacing drive belt, [954-0467], my troy bilt bronco won't fully stop, and the transmission control lever is difficult dto shift. When I turn off the ignition brake functions and shift lever...
The new belt is too tight.Look for an adjustment on the control lever or tension pulley.If that wont fix it.Remove the belt and take it to a NAPA.They can make you a new belt just 1/8 inch longer.I have had to do that with an old mower I had.
Thanks for using Fix Ya,I hope this helps.
Jun 03, 2011 | Mtd Drive Belt 42"
How do I know if I am replacing my mtd rider mower belt correctly
The rule of thumb for the routing of the mower belts is to make sure the "V" inside of belt is fitted into your pulleys. The "FLAT SIDE" outside of the belts rides with the flat side up against your idlers (lookes kinda like a pulley but is wider.) It might take you a couple of attempts to get it right. When the belt is on properly it will be nice and snug.
Good luck
roundo4
May 23, 2010 | Mtd 22" White Outdoor Self Propelled High...
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yard Man 42'' Drive Belt Install
it is a mtd mower ,however you should be able to go to a tractor supply store with the decksize and the engine size and get the proper belt.AGAIN(TSC) store,OR TSC.COM HOPE THIS HELPS
Jun 08, 2009 | Mtd Garden
Mtd FASTATTACH MANUAL SLEEVE HITCH Logo
2,673 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
