Question about Acer Aspire One PC Notebook
What should the high and low pressure readings be on a 98' honda civic
    Brigadier General:
  • 10,406 Answers
>> All Products > Acer > Aspire One PC Notebook > Troubleshooting
The "operating range" for a typical notebook computer is between 0 degrees to 60 degrees Celsius, i.e., if water near the computer is freezing, don't turn the computer on. Similarly, if you're inside a very hot sauna, don't turn the computer on.
Posted on Jun 01, 2009
Honda Civic hybrid low oil pressure light EPS light blinking drive light no speedometer
fixya, hybrid fixes.. wow......
double posted too,,,, back up one.
wendy dont fiddle about in any hybrid, there is High voltage there
lethal as H3LL. nor with Air bags, Read the FSM. first.
and post engine RPM at low oil pressure, and dont drive it.
Jan 19, 2014 | 2005 Honda Civic Hybrid
P1129 02 Honda civic, map reading too high
Problem with Suzuki Cars & Trucks P1129 02 Honda civic, map reading too high
honda or suzuki?
Manifold pressure sensor.l
your idle is too low? what is it cold and hot.
you have a gross air leak (vacuum) to the intake plenum
the sensors , almost never fail. it also wastes fuel like this.
Oct 15, 2013 | Suzuki Cars & Trucks
1995 Honda Civc failed Emmisions test
Emission test by codes reader? or smog? Any codes?
May 22, 2017 | 1998 Honda Civic
My 1997 honda civic idles high and low when stop at lights
sounds like the idle air control valve. does the check engine lite come on? if so have it read and repaired.
Jan 23, 2011 | 1997 Honda Civic
Hi,i have a honda civic 1.4 ,2005 model and have a noise from drivers sid wheel,i suspect the power steering fluid level is low but i am unable to locate the reservior?
Is the fluid pink to dark red color?
Power steering high pressure hose,low pressure and/or steering rack can be the source of the leak.
Feb 02, 2010 | 2005 Honda Civic
A/c for honda 2000 blows cold but has erratic high pressure readings very high and very low readings on low side
evacuate system and refill to proper spec for r13a refridgent may not have proper levels. check cooling fan opperation with engine running cooling fan should be opperating while a/c compressor is engaged. if all theese check out good has blockage in system
Jul 31, 2009 | 2000 Honda Civic
94 civic a/c
Look at the LOW pressure gauge reading when the engine is OFF.
On an 80 degree day, the LOW gauge should read about 56 psi or higher if the A/C system contains an adequate charge of refrigerant.
On a 90 degree day, the LOW side reading should be about 70 psi or higher.
If the LOW gauge reading is less than this, the A/C system probably needs some additional refrigerant.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 22, 2009 | 2003 Honda Civic
Low beam headlights on 95 honda civic dx
Im just curious if you found a fix for this issue because I'm curently having the same problem with 98 civic?
Jan 19, 2009 | 1995 Honda Civic
98 honda civic, when the car is D4
More than likely one of the shift solenoids is bad.
Jan 03, 2009 | 1998 Honda Civic
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
