Question about Toshiba Satellite M45-S2653 Notebook
Laptop will not shut down
I have a Toshiba Satellite M45-S2653, and for some reason when we go to start>shutdown it will not shut down it just sets there for 1 to 3 hrs then we have to hold the power button down for it to shut off, what could be the problem?
  • meteshadow May 11, 2010
    any message on screen ?
    Brigadier General:
  • 10,406 Answers
Check the "Power" option in "Control Panel".
The ON/OFF can be programmed to either put the computer to "sleep" (by touching it once), or to immediately shutdown Windows (by touching it once), or to require that you HOLD the button down for 3 to 4 seconds, to REALLY confirm that you want to shutdown.
Posted on Jun 01, 2009
    Guru:
  • 597 Answers
Try following this report suggestions.
http://support.microsoft.com/kb/308029
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
M45-s2653 laptop freezes on restart
when you start having this problem it's normally caused by a critical systems error. worry not.. with a little time on your part we can fix this- this is how-
Go here
using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe. Burn this on a disk, the program is written with freedos, but this will not work with 100% of laptops. if freedos won't work then you need to use a program such as PowerISO to burn the disk and make it a bootable image,
after burning the program to disk-
  • insert disk and reboot
  • press any key to boot from cd if asked
  • when you see Prompt, change to cd drive
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
Sep 14, 2009 | Toshiba Satellite M45-S2653 Notebook
Will not shut down
you can go to the control panel, find power options, and than set how you want buttons to react.
Jun 01, 2009 | Toshiba Satellite M45-S2653 Notebook
Programming buttons for player and explorer on the satelite keybo
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Satellite+M45-S2653&x=0&y=0
There you go
Apr 15, 2009 | Toshiba Satellite M45-S2653...
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
I have Ubuntu on my notebook right now and I want Windows XP back but I can't find the drivers on the toshiba website. I have a satellite m45-s2653. thanks!
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1192108&rpn=PSM40U&modelFilter=M45-S2653&selCategory=3&selFamily=1073768663&selModel=1192108%7CPSM40U
Dec 20, 2008 | Toshiba Satellite M45-S2653 Notebook
Toshiba satellite m45-s2653
dear
the fan is separate, just connect by cable
oke
cropp
Mar 18, 2008 | Toshiba Satellite M45-S2653...
Satellite m45 s2653 keyboard replacement
If this answer doesn't rate a "fixit", I don't know what does.
Steps 9 through 12.
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_2.htm
Good Luck
Jan 02, 2008 | Toshiba Satellite M45-S2653...
Computers & Internet Logo
170 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
