Question about John Deere 4020 Gas & Diesel Tractor Radiator
4020 w/ 24v system sparks when the battery is connected
On a john deere 4020 w/ a 24 volt split system sparks when the left cable is connected to the battery and makes the wires going to the generator and regulator hot. ??
  • rjivaro May 11, 2010
    It sounds like you reversed the polarity on one or both batteries. If so, it is possible you damaged the generator and/or regulator so that even if you do connect them correctly you will still have a short. Not neccessarily, but it is possible.
    Get a wiring diagram and make sure they are connected correctly. If the sparking continues it will require further work.
    Problem Solver:
  • 4 Answers
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
Posted on Jun 05, 2009
John deere 170 with a kawasaki 14hp engine. Battery has 11 volts. I turn the key nothing happens when I jump the solinoid the starter hums. Any help is greatly appreciate
Battery is low. Either the battery is bad or the charging system is bad. You should read 12.5 volts or more when not running, 14 volts when running.
Mar 29, 2016 | John Deere Garden
Looking for a download for electrical wiring diagram for a John Deere LT190
LT190 - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM152795.../OMM152795_H46.html
Disconnect spark plug wire(s) or battery negative (-) cable to prevent engine from starting accidentally. · Always wear gloves when handling mower blades or ...
Oct 15, 2015 | John Deere Garden
What could cause a spark when I install the positive battery cable on my John Deere 4240?
Sparking between the lead and positive terminal when connecting them is normal. But you should always connect the positive first then the negative.
Dec 18, 2014 | John Deere Garden
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
Can I jump start a john deere 445
Yes, you can jump start it with any 12 volt battery on any vehicle. Just do not have the donor vehicle running. Connect the positive cable from the donor battery to the positive post on the battery on the mower. Then connect the negative cable from the donor battery to the engine block or other ground source on the mower. Do not connect it to the negative post on the battery. Make sure you have a good connection on bare metal for the negative cable. Disconnect the negative cable the instant the mower starts.
Aug 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
John deere turf tractor has no power, recharged battery for 24 hours but still zero power. Checked all connections, everything is connected. Tractor is approximately 6 months old
check the battery with a multimeter and see if its showing 12 volts or more, if its not showing any volts the connectors on the battery under the plastic housing have probably come disconnected, you'll then have to pry off one side of the battery and reconnect them, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Apr 26, 2011 | Peg Perego IGOR0040 John Deere Turf...
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
1,155 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
