Magnavox 51mp3964h/17 has 3d effect
The red and green is out of wack
hopeing someone can tell me whats worng with it and what to fix
i tried to fix in the settings but could not get them to line up
and were to get parts
  • 8,617 Answers
You can get the repair kit at the following link to reapair the convergence issue. The kit contains the two Convergence IC and the 12 resistors plus step by step instructions how to do the repair. Heres the link for the correct kit for your model which is the Mag 01 chassis.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Posted on Jun 01, 2009
Whats wrong with my big screen 52 inch
Possible this can be fixed with a professional alignment as the adjustment of the convergence is distorted and so needs a setting.
The Keystone correction and focus must be adjusted.
check this link for tips:
http://htrgroup.com/main.php?section=keystone
Dec 20, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The picture on my hitachi 42' r out of wack~ I checked the back an the red light wont line up with the blue an green~ Is there any way I can move the red manualy~? I covered the red for now so I can c the...
gui harcor,
Sounds like you have a classic case of convergence IC failure. It will only get worse if you do not fix it. It is repariable by anyone with patience, some skills with tools, good soldering skills and of course someone who is very conciencious. If you still want to try to give it a shot I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will walk you through the process as well as link you to the very best place to get the repair parts.
Thanks for using FixYa and for the excellent rating. Great ratings keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | Hitachi 43FWX20B 43" Rear Projection...
My magnavox 51mp392h has a convergence issue. the
Convergence is dead.Know how to solders? Must replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.The shop will $300 for the parts and labors.
Feb 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H Rear Projection Television convergence problems
You need to try to adjust it with the original remote in the TECH mode---you can save the adjustments there--
With the set on a video input with nothing connected:
hit the following buttons: 0 6 2 5 9 7 STATUS
The menu should appear with choices---green(do not adjust green) red to green, blue to green etc.
On that initial menu will be a item that says store or save. Depending on the remote you have once you select red to green (cursor on remote) a grid of lines should come up---on screen will be instruction--menu to adjust and or status to navigate.
When you have the red--to green adjusted hit the status button until it takes you back to the menu where Store or save is listed and right cursor on it.
This will store the adjustments.
Go back by selecting blue to green and adjust that also and when done go back and save it.
Turn the set off to exit the service mode and see what you have---IF THE SET DOES NOT RETAIN these adjustments made in the Tech menu something is wrong with its DCU--digital convergence unit---that stores the adjustments.
Let me know if you have questions as I am here to help people.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
I replaced the Convergence ICs (STK392-120) in my Magnavox 51MP3964H/17, but when we soldered the new ones in, there was a solder bridge. We fixed that problem but the red is still out of whack. (Still...
Check the resistors around the amps. Many times one or more resistors are blown, but they may visually look fine.
Check all of the pico fuses.
Also,
Sep 10, 2009 | Televison & Video
Black Bars and Power Issues
Sounds like a solder bridge bewtween the IC pins double check the solder for any pins accidentally bridged with solder.
Sep 06, 2009 | Televison & Video
Magnavox 51mp3964H/17
You need to replace Both of your STK convergence ICs they are big black ICs will have part number on them STK392-110 ,ect if you can solder you can fix it your self ,TV repair shop m/b 300.00 also you will need Service Code to be able to enter into TECH alinement mode .Call Mats Electronics for parts 1-800-628-1118
Aug 18, 2009 | Philips Televison & Video
Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Jul 20, 2009 | Thomson Televison & Video
Sony Wega, 60" LCD
I hope you know the light engine to these sets cost 1,900.00 up to 2,500.00 also did you reset lamp timer when you installed new lamp to tell set lamp has 0 hours on it?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Televison & Video Logo
272 people viewed this question
Top Televison & Video Experts
