Question about Tech Solution TS-8000 Cross-Cut Shredder
Tech Solutions shredder Only powers in reverse w/ green light
Tech Solutions 8000 cross shredder. When button is in ON position: no lights, no power. When button is in REVERSE position: green light, powers on. Have read that it could be paper caught around the mechanical paper feed sensor. Where is the mechanical paper feed sensor and what do I need to do to troubleshoot? Thanx Motor and everything else works fine when you press the reverse button, but does not work at all when pressing the "shred" button. Effectively makes this machine useless unless it can be fixed.
  • 328 Answers
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Posted on Jun 05, 2009
What is the red light next to the green power light? It appears to look like a temperature light. My unit won't run.
In most cases it means the shredder is full or something is jammed. Empty the shredding container. If the machine has a "reverse" position on its switch, try running it backwards to get whatever is jamming the teeth to come back out.
Nov 03, 2014 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
Where can I get new gears for my Tech Solutions TS8000 paper shredder
Unfortunately there are no replacement parts for many shredders...they are made to throw away when the break...
Stinks... but that's the way it is...
heatman101
Jun 15, 2011 | Tech Solution TS-8000 Cross-Cut Shredder
Reverse works but forward will not engage.
Your problem is within the "switch" if you can only use it in reverse. Unfortunately, no parts are available for that "discontinued" model. Best answer is to buy a new shredder.
Jan 23, 2011 | Tech Solution TS-8000 Cross-Cut Shredder
Where should I oil my TS 8000?
Oil directly into the cutter blades from the top, then reverse and repeat.
Jun 06, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
These are made by Winsource Industries http://www.winsource-hk.com/ The contact information is Hong Kong. I haven't had any luck getting a replacement for one with a Limited Lifetime Warrany.
Good Luck -
Jan 25, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
920 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
