Question about Garmin iQue 3600 GPS Receiver
Changed battery---record switch came apart, screen wires came off of mother board.
Screen Wires have come loose from the mother board.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
I have an iQue 3600 apart right now. One of my screen wires has come off the board. There are two large solder pads to the left of the left-most white push button. Red wire goes to the left solder pad; black wire to the right one. You need to strip a little insulation from the wires and solder them back on. If you have not soldered before, find someone to do it for you!
Posted on Jun 04, 2009
Frozen screen
1) clean the contacts batteries from dirty, oxide, with specail spray clean contacts.
2) resolder the wires contact batteries for a GOOD contacts.
3) tight the Ribbon cables 4) Tight the wires connector from display board vs lower board see the block
5) Adjust the REED switch, clean it, and tight the wire connector, see the diagram 6) After you fix it , RUN the software calibration for diagnose and fix it.
God bless you
Jun 28, 2012 | Universal Remote Control MX6000 Remote...
I dropped my T4220 and now the screen is blank and its beeping. There are no visible cracks on the screen or the casing... The fan is on and nothing else :( Any help pls...
There could be anything from a wire off to a hair line crack on the mother board. If nothing much works apart from the fan, it is possible the mother board is now damaged.
Feb 15, 2011 | Fujitsu LifeBook T4220 Tablet PC
My top screen is separated from my bottom screen but it still works because a part from the right hinge broke off. The only problem is that my microphone doesn't work. How can I fix it?
There are 2 thin wires that run along the inside of the spine that clip onto two connectors on the mother board - one is the microphone. It sounds like this has become dislodged. Unscrew the back and check if one of the two wires is loose. On YouTube there is a great tutorial for "how to repair Nintendo DS Lite touch screen by supermodchips that explains very clearly where this wire should be. Good luck
Dec 27, 2010 | Nintendo DS Lite Console
The radio lights up charges a battery but there is no sound
the speaker wires might be loose or touching take the radio apart and follow the wires to see if its just the wires if they are fine check the souder points on the mother boards
Nov 06, 2010 | Dewalt DC011 AM/FM Radio
Heater/AC control no longer allows change in temperature
You have one of two possible problems.
1) The temperature shaft retention nut is loose behind the knob
2.) The wires to the potentiometer part of the temperature may be broken.
Either one is common to this vehicle. The replacement of the AC controller is about 900 dollars. If the wires are broken, they can easily be reattached to the circuit board via soldering. What you would have to do is remove the control box from the dash, and disassemble it. Once the unit is apart, there are 3 wires from the temp knob to the circuit board that need to be re-soldered. The unit CAN be repaired, as opposed to the expense of replacing it.
Apr 23, 2009 | 2006 Toyota Highlander
Can't Remember where wires go.
probably these wire nowhere connected if you have no wireless lan adapter. Usually these two wires join to built-in antenna in screen.
Mar 04, 2009 | MSI Micro-Star ATHLON/DURON UP TO 3200+...
Bottom screen
a wire has disconnected, you have to take ds apart again (not fully) just so you have access to motherboard with black and white wires showing. look to where the black wire is fixed on and below that to the edge of the board you will see a tiny piece of see-through plastic with black lines through it, (mine had come loose and i had fastened ds up whilst it was curved underneath board). you should also see there a slot approx 2mm at most with 3 / 4 bronze/gold prongs ( very much like smaller version of the large wide wires and slots they fasten into) you dont have to flip anything up to get this wire in or out, just slot in carefully (i used tweezers) as far as will go, making sure you dont disturb placement of any other wires. now put shell back on and before you put screws in just switch ds on to see if problem is solved. hopefully ! mine worked fine after this.
Jan 07, 2009 | Nintendo DS Lite - Onyx
Psp screen wont work with my old motherboard
ok i know whats wron here i just need to replace the mother board
Dec 04, 2008 | Video Game Consoles & Games
CMOS
open the screen flat out, carefully prise up the plastic over the two hinges, remove the three screws holding the keyboard in and then the metal flap beside the heat sink, it is under there, you need a cmos battery with 2 wires connected to a plug, as yet i havent found a source for that, i used a standard battery and taped the two old contacts to it, worked for 18 months ok
Jul 19, 2008 | Fujitsu AMILO D-7820 Notebook
Garmin iQue 3600 GPS Receiver Logo
166 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
